Pop Pop Pop
1981 911sc
Pcar runs very well. Except.......
in mornings when I first start up there is a pop pop popping sound coming from the airbox. I don't have a popff valve.
doen't happen after car is running.
What would i look at to see what is causing this?
Tx!john
Old 03-02-2003, 11:47 AM
tight as a bull's ass's Avatar
before you do anything else....get a Pop-off valve ASAP.
A blown air box will cost you over 1 grand to replace....ask me how I know..
www.swirlednews.com/article.asp?artID=501
The data in the CD-type disc decodes easily into ASCII computer text as follows, using 8 bit binary:
"Beware the bearers of FALSE gifts & their BROKEN PROMISES. Much PAIN but still time. (Damaged Word). There is GOOD out there. We OPpose DECEPTION. Conduit CLOSING (BELL SOUND)”
The damaged word would appear to be intended as “BELIEVE”.
Old 03-02-2003, 12:42 PM
ok, i'll get one. Would i then have to close the popoff valve each time it is forced open. also, what would be causing the popping?
TX!john
Old 03-02-2003, 12:46 PM
TX!john
no, the valve is spring-loaded....once it is forced open from the internal pressure release, it will close by itself due to its built-in spring. see pic below.
Old 03-02-2003, 12:47 PM
i see said the blind man.
so, any idea to make the poppung go away?
Old 03-02-2003, 12:53 PM
hey mr. flat, i dont know too much about these 911 motors, all i know is that they are 2 cycle motors...and that's about it.
just get rid of the internal pressure buildup and your popping will go away. this may sound obvious, but the sooner you understand the phenomena and source of the problem, the sooner you will arrive to the solution...good luck
Old 03-02-2003, 12:59 PM
