Targa interior bar trim
Hi,
As part of the effort to reduce (probably impossible to eliminate) the squeaks, rattles and weird noises on this car I found my interior targa trim was barely hanging by the side bolts, nothing else was holding it in place.
I also fixed the leather coming undone on few rear trims.
I noticed the interior targa trim is held by a system of locking pins.
One needs to slide the trim from the back of the car to get the trim locked.
This seems to be a challenge as the portion of the trim is hitting the rear window seals thus the condition of my trim, I guess the previous owner just abandoned the idea and left it as is.
What is the trick of tucking the trim in place?
I will attempt to put felt at areas that have leather on leather and plastic on plastic to reduce the creaks.
Thank you
1974 911 coupe 4 speed
Old 07-25-2018, 09:49 AM
Administrator
Dmitry at Pelican Parts's Avatar
Hello - take a look at the link below to an earlier thread where the targa bar is reconditioned. Hope this helps you out a bit!
Targa bar interior vinyl recondition
Old 07-25-2018, 01:53 PM
RDM RDM is offline
Coram Deo
RDM's Avatar
Hey, that's my thread!
Ayles is really the expert. I have now replaced my windshield and targa window seals, so my bar cover is back out again.
I'm following along, and re-redoing mine.
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
Old 07-26-2018, 03:54 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Consider installing a Targa Body Brace, this will reduce allot of top squeeks and make the car less the dreaded Targa/Cab flex
'85 Carrera Targa
PCA/POC
Old 07-26-2018, 09:29 AM
Hi there!
It's now going on a few years since I have done this... on each of the tabs there was a piece of felt split between the top and the bottom. Maybe a half inch square on each tab. That should quiet it a little there as well.
I needed help to get the bar in. I wasn't able to engage all of the tabs on my own. You will feel it lock into place and it will be snug up against the front portion.
1982 911 Targa, 3.0L ROW with Webers
Old 07-26-2018, 10:23 AM
Targa_PB_78_SC
mike sampsel's Avatar
Is this part (body brace) available at pelican?
Old 07-26-2018, 05:39 PM
rokemester's Avatar
The brace pictured is NLA but I remember an old thread that has been updated recently. FS: Targa body braces
Northeast Ohio
1987 Porsche 911 Targa
1966 VW Beetle, 6V
Old 07-26-2018, 06:32 PM
DRACO A5OG's Avatar
NLA, a Member had made a bunch for sale or you can make one like it did
'85 Carrera Targa
PCA/POC
Old 07-26-2018, 09:20 PM
Bret Krause has a Targa harness bar that has a similar construction to the body braces. I got one on eBay for $100 and they have come up a couple time since. Car is sold as a rock since I put it in.
Old 07-26-2018, 10:40 PM
