-   -   Delete clock for volt meter (http://forums.pelicanparts.com/porsche-911-technical-forum/1003917-delete-clock-volt-meter.html)
Snitzler 08-01-2018 10:07 PM
I would like to delete my clock for a volt meter. I found a plug for the hole but with shipping it works out to around US$40.00. Since I am going to cut a big hole in the plug it seems like a big waste. Has anyone come up with a cheaper solution? I am going to hit the big hardware stores to see if I can find anything. BTW, I am going to keep the clock, it works great and if I change my mind one day, I can put it back in.
93nav 08-01-2018 10:46 PM
If you do a search, this has been brought up before. Some have left the clock in place and put the voltmeter elsewhere. Plus other options.
rnln 08-02-2018 01:58 AM
I thought about using a bad stock clock as a housing. Fit a smaller volt meter inside the dead clock. well, I have not have time to do it yet :D
blucille 08-02-2018 03:56 AM
You can get a volt meter that plugs into your cigarette lighter....or replace your lighter with a USB port with volt meter.
I like having the cigarette lighter so I can use a tire inflator.
So, I replaced my brake and seat belt warning light with a USB charger with volt meter.
All of the above can be found on amazon.
The longer story is that I put the gas and oil gauge over where the clock used to be, and put an AC vent on the far left.
zedsn 08-02-2018 04:08 AM
I mounted a volt meter below my ashtray.
MrBonus 08-02-2018 05:17 AM
I use one that fits in the cigarette outlet and even comes with a USB outlet.
pampadori 08-02-2018 07:26 AM
Just purchased a cigarette lighter volt meter/USB charger on smile.amazon.com for $15 and free same-day delivery. What a world we live in!
https://images-na.ssl-images-amazon....L._SL1200_.jpg
pampadori 08-02-2018 07:28 AM
I have to be honest, i surfed north hollywood speedo's website for about 30 minutes and almost decided to have my tacho rebuilt with an additional voltmeter added to it. Then i recalled that I'm not made of money and went with the $15 option mentioned above!
