175K911's Avatar
What gaskets with headers on 964 engine?
Installing my George's headers on my 3.6 tonight, almost ready to pull it off the engine stand after 7 years.
So what gaskets do I use? Ideally the OE 964 sealing rings, but the flanges are a lot thinner than the OE heat exchangers so I'm concerned that tightening them down will warp the flanges ever so slightly. Or do I use a traditional exhaust gasket?
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 08-08-2018, 12:08 PM
3rd_gear_Ted's Avatar
Suggestion: traditional gaskets copper faced on both sides with castellated nuts
1980 911 - Metzger 3.6L
2016 Cayman S
Old 08-08-2018, 01:32 PM
Mahler9th's Avatar
My application is racing.
I have always used the standard factory style metal gaskets between the heads and racing headers. I have used European headers, S Car Go headers (excellent), and some headers which are very similar to the SCARGO in design (also excellent; acquired from William Knight).
The gaskets can be obtained from all of the usual places, including our hosts at PP. I usually use new gaskets each time no matter what.
Not sure what the torque spec is. I do not use a torque wrench for this.
I always use new copper heat nuts and washers. New nuts EACH time.
I use nuts with 12 mm hex heads-- you can also use the ones with 13 mm hex heads.
Mike
PCA Golden Gate Region
Porsche Racing Club #4
BMWCCA
NASA
Old 08-08-2018, 01:34 PM
Under the radar
Trackrash's Avatar
Don't forget the anti-seize.
Gordon
'71 911 Coupe 3,0L outlawed
Old 08-08-2018, 01:37 PM
175K911's Avatar
Thanks guys.
Mike- my application is racing too. NASA GTS3 or PCA GT-3S
The heads have all new studs, Wrightwood Racing engine gasket set came with all new hardware and the 964 style metal o-rings. Always new hardware and gaskets- cheap insurance.
Ed
Old 08-09-2018, 08:26 AM
175K911's Avatar
Thanks guys.
Ed
Old 08-09-2018, 09:33 AM
