Jeff, I hope I didn't send you on a wild goose chase.
Mark's input is good and I know Ivan to be very knowledgeable. Good luck. |
Jeff to find out if your sensor has been cut out is like this.If your control box goes all the way up to max heat in any speed(number) the connection to the sensor connection has been corrupted.
thanx Dan..... Ivan |
Mark I havnt looked for the exhaust one as yet I am unable to jack her up as I am looking for a replacement jack, but the wiring is there on the control unit do you know what the two brown wires are for that come from the back there are 2 yellow ones also that come from under the carpet should these red ones be connected to the yellow ? They have suitable spade end connector
Jeff |
Report Post Pelican Parts Catalog | Tech Articles | Promos & Specials Reply With Quote Multi-Quote This Message Quick reply to this message #22 (permalink)
jeffcavalier jeffcavalier is online now Registered User Join Date: May 2016 Location: Manchester England Posts: 26 Mark I havnt looked for the exhaust one as yet I am unable to jack her up as I am looking for a replacement jack, but the wiring is there on the control unit do you know what the two brown wires are for that come from the back there are 2 yellow ones also that come from under the carpet should these red ones be connected to the yellow ? They have suitable spade end connector Jeff |
Everyone I have ever seen up to '86 is in between the visors as stated earlier..
Mark |
