-   -   Sensor location for Auto heat controller (http://forums.pelicanparts.com/porsche-911-technical-forum/1004211-sensor-location-auto-heat-controller.html)
jeffcavalier 08-06-2018 05:47 AM
Anyone know were the internal temp sensor would be for a 1979 911 SC Targa , I have checked behind internal mirror
Flat6pac 08-06-2018 05:48 AM
That’s where it goes on the 0-10 controller.
Bruce
86 911 Targa 08-06-2018 06:38 AM
Sensor.
For our M/Y 86, it is located to the right of the steering column.
Gerry
86 911 Targa 08-06-2018 07:50 AM
Sensor.
http://forums.pelicanparts.com/uploa...1533570602.jpg
Here
Gerry
jeffcavalier 08-06-2018 08:29 AM
Thanks Gerry mine has a different arrangement
The vents are rectangular I will try and get the fronts off and see of anything in there
Jeff
T77911S 08-06-2018 08:55 AM
I mentioned it is in the dash In one of your other posts
steely 08-06-2018 10:50 AM
Maybe the 79 is different(?)
Could it be tucked up under the dash and not have it's own 'vent' ? (it's really not a 'vent' but an aperture sort of).
steely 08-06-2018 10:51 AM
aha
carreradpt 08-06-2018 12:05 PM
Jeff, when you get the front off would you post a pic of the sensor? Thanks
jeffcavalier 08-06-2018 12:12 PM
I have been all over the under dash board and bought a cheap enderscope to look down the vents but still no look
The wire does head that way somewhere behind the dash I will keep looking perhaps it's been removed in the past!
SilverWT 08-06-2018 01:45 PM
Up until MY '85 the cabin auto-heat sensor was located on the roof in between the sun visors...
http://forums.pelicanparts.com/uploa...1533591841.jpg
After this is was in the dash.
Mark
jeffcavalier 08-06-2018 10:43 PM
Mark.
Was so for the Targa
Jeff
SilverWT 08-07-2018 12:23 PM
If you had auto-heat (i.e. the original control box between the seats could be adjusted from 0 through 1-9 to DEF), that is the only location for the cabin temp sensor prior to '86.
Mark
jeffcavalier 08-07-2018 12:25 PM
Mark,
The interior light is in this location
SilverWT 08-07-2018 02:54 PM
Only one sensor, mounting and wire is listed.
http://forums.pelicanparts.com/uploa...1533682061.jpg
SilverWT 08-08-2018 02:50 AM
To make sure I'm not going senile, I just checked with a couple of Targa owning Buddies.
They both confirm they have the cabin temp sensor between the sun visors the same as the Coupe. They also confirm that their interior lights are in the Targa hoop.
So it would seem if a Targa came with the auto-heat option the interior light was relocated. If so, maybe your car never originally came with auto-heat, just the manual version.
Is your car an original RHD UK spec car, or an import?
Mark
jeffcavalier 08-08-2018 03:22 AM
Hi Mark it's a right hand drive registered in England
It definitely did have the controller as all the wiring is visible under the unit , perhaps the sensor was relocated sometime in the past
Jeff
jeffcavalier 08-08-2018 03:24 AM
It's a real mystery I need to try and trace the wire I think the sensor has been cut as there is open circuit
Jeff
proporsche 08-08-2018 03:28 AM
Jeff is your auto heat working....?
Ivan
SilverWT 08-08-2018 09:05 AM
Jeff
From new, a C16 car?
Jeff
The manual heater unit would have had a controller that looks the same, except for the dial only being 0-3 and it some had wiring underneath.
Not just relocating the sensor, but the interior light as well?
Does the car have the temperature sensor in the nearside air duct just ahead of the flapper boxes (under the car next to the gbox)?
Mark
