Fan and Shroud Differences
Hi All,
The following table lists two different fan and shroud assembly part numbers, but the same shroud casting number (901.106.101.5R). This shroud casting number is listed for 69-74 and 75-77. I need one for a '72 2.4L, so how do I tell if I'm buying the correct one, as the shroud number does not distinguish them?
Old 08-11-2018, 05:45 PM
Bill Verburg's Avatar
Originally Posted by dennisO View Post
Hi All,
For a '72, 901.106.011.00 is the one you want
Bill Verburg
Old 08-11-2018, 06:16 PM
Bill,
thanks, but how do you tell? I only recall seeing a shroud casting number. Are there part numbers as well?
Old 08-11-2018, 06:29 PM
Bill,
I posted the part #
Bill Verburg
Old 08-11-2018, 06:30 PM
sorry, but I'm missing something. I guess I'm not asking the question correctly. how do I determine the part number of the fan and shroud, as all i see is the casting number, which does not map to a unique part number?
Old 08-11-2018, 08:57 PM
Wildman Emeritus
Use the shroud number listed for your year as Bill stated. Ignore the casting number as it is common practice to utilize one casting to produce multiple, slightly different finished parts.
If you have a shroud, what number is cast on it?
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 08-12-2018, 06:46 AM
