Hey guy's,
I have a question, My car is missing on a cylinder but this only happens when the distributer is making a grinding type sound like a bad bearing or something.. and while it makes this sound the cars seems to stumble a bit and runn rough like it's got a bad plug/ wire or shat have you.. and the motor is smooth but the Distributer is rough to place your habd on it feels rough.. and once and a while it will stop the grinding sound and the motor seem to pick up the cylindr again, and runn GREAT! but as soon as that sound of roughness comes back from the Distibuter it startrs to stumble again.. Would the distributer going bacd be the cause of this? Is there any way to check as they are NOT cheap!! Thansk, I have a 78SC Tub w/ a 83 SC motor.....if this helps.. Thanks in advance! Eric Mckenna
Famous last words.. "Hold my beer and watch this...' " The reason the Irish are always fightin one another is that there are no other worthy opponents ". |
Eric,
I have had my dizzy go out on me twice. Both times the car started missing progressively worse and then finally died. The easiest way to check is to pull the distributor cap and check the shaft for looseness. If those bushings are bad you will be able to move the shaft very easily. Also check to see if the rotor or cap is cracked. Mine were and it was obvious that they touched. I got mine rebuilt locally for around $150. Pete
1983 SC 1958 TR3 2014 Cayenne GTS (wife' car) 2006 KTM 450EXC |
When your dist. starts to drink alot and pick up on hookers, then i would say its going bad.
Try the link below...its a rebuild kit.
Yep it's loose!!! so I will be rebuilding it.. as mine is doing what yours did! it is getting worse... Thanks! and Thanks Jer.. I'll be getting one of the rebuild kits.. unless I can track down a good one for a good price. Eric
Senior Member
Let us know if you are able to find the bushings. The kit on eBay provides for the reluctor, etc. but does not have the springs, spring pole plastic covers, or the pair of bushings or pinion pin. Those are the items you are going to need should you decide to strip that dist.
John
'78 Targa in Minerva Blue |
Eric,
you may borrow mine out of the SC, until you get yours repaired. that way it gives you some time to enjoy the car and fix your dist. rather cheaply....cheaper than a new one anyways. let me know if/when you want to do this. I will bring my timing let to set it to match your current timing. shouldn't take very lone. 1/2 hour. Last edited by Jbabic; 03-03-2003 at 07:52 AM.. |
Would this work for you?
Saw this over in the Classified forum, don't know if it would
fill your needs... Rare Marelli Distributer
Impotence...Nature's way of saying "No hard feelings." McDaniel 1974 911 Targa 1995 Toyota Avalon 2004 Toyota Tundra Extended Cab |
Senior Member
Remember that the early '78 dist. uses a different pitch on the pinion end (this changed for the remainder of the SC line). You have an '83 so be careful here should an early '78 dist. be offered.
And of course the SCs dist. direction is different than that of earlier cars. Worth noting anyway, John
