Targa_PB_78_SC
mike sampsel's Avatar
Crud in my oil cooler fins cleaning ideas?
With the shroud off I can see there is crud (oil and dirt from the TOD leakage)
in my oil cooler webbing.
maybe I should spray brake cleaner from the top down to clean it some?
Not able to get a power washer to it.
Cooler in the engine and engine in the car.
There is definitely something relaxing cleaning grease off the old friend
Old 08-28-2018, 11:07 AM
I believe that most shops submerge the entire oil cooler into a cleaning tank.
1987 Porsche 911 Carrera Coupe
Old 08-28-2018, 11:12 AM
An engine degreaser/cleaner that is safe to use while the engine is in the car works pretty well. Some agitation with a soft paintbrush helps too. I used the GUNK brand but there are several brands available.
Here is a before and after pic of my oil cooler.
Brian Miller - Scottsdale, AZ
1971 Porsche 911 T Targa @targatuesday :: 2005 Ducati Monster S2R :: 2008 Porsche Cayman S
Old 08-28-2018, 11:19 AM
Perpetual Reassembler
2jmotorsports's Avatar
Drop engine, remove, send out for ultrasonic cleaning.
Continue down slippery slope...
Jose - 1983 911SC Coupe
Instagram: @joe_engineer
911 D I Y Blog: joe-engineer d o t c o m
D I Y Vids: https://www.youtube.com/joeengineer
Old 08-28-2018, 11:20 AM
Targa_PB_78_SC
Thanks guys, I'm liking Brian's pictures
I also have an air compressor and can push some crud down the cooler once it is loose.
I've heard the cooler seldom leaks at the o-rings, so its staying attached for now.
Old 08-28-2018, 11:53 AM
You might try a compressor air nozzle with a siphon hose to de-greaser or paint thinner. It will make a bit of a mess if you do it over concrete.
Old 08-28-2018, 01:17 PM
Ctopher's Avatar
I've not cleaned any of the coolers on my car yet but be careful with how much air pressure and how close you get to the fins as you don't want to bend them. And if you have any bent fins you can get a radiator fin straightener to stand up the fins and help restore some cooling efficiency.
I'm planning on pulling my front oil cooler and wasn't sure what I was going to use beyond water and some simple green aircraft to clean it.
Ctopher
Old 08-28-2018, 01:26 PM
Flojo's Avatar
I cleaned mine when installed from above soaking it in brake cleaner, poking it with Schaschlik wooden sticks (long and slim) and airgun to blow it through.
What a mess it was....
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 08-28-2018, 01:41 PM
Depending on how much crud is there home depot sells and air conditioner fin cleaner in an erosal can for outside ac systems that you might want to try.
Old 08-28-2018, 02:27 PM
Fleabit peanut monkey
Bob Kontak's Avatar
This is just oil.
Awesome, Fantastik, brake/carb cleaner, kerosene, gasoline, lacquer thinner or whatever floats your boat.
The AC condenser cleaner I don't think is meant for hydrocarbon buildup. However, it probably would work as good as the any of the above mentioned cleaners. Just expensive.
I bought Awesome the other day at Dollar Tree for a dollar. Just saying.
Air hose or water hose (if you are ok with the flood).
Doubt air hose would wrinkle those fins even if you tried.
1981 911SC Targa
Old 08-28-2018, 04:26 PM
clarkd's Avatar
My cooler was oily with fur, bits of nut shells and rodent crap. I tried to clean it in place with limited success. I wound up soaking it for a minute or so in a bucket of hot water with dawn dish detergent. I pulled it out of the hot water and blew through it with compressed air. Repeated at least a dozen times until it was clean.
Old 08-28-2018, 05:52 PM
Kerosene or WD40 will dissolve that.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 08-28-2018, 05:55 PM
SCadaddle's Avatar
"I bought Awesome the other day at Dollar Tree for a dollar. Just saying."
Yep. I bought it at Dollar Tree for a dollar the other day as well. My lady friend found out it's not so awesome on a wood coffee table.....
I had a lot of nut shells in the fins of my oil cooler a few years ago when we had the engine out. Tapping it on a wood block on the garage floor dislodged most of it in short order, however, I actually considered plugging the inlet and outlet holes, spraying it down with a mixture of water and sugar to get all the offending particles nice and tasty, then toss it on to a large fire ant bed. Let them have at it.
Old 08-28-2018, 06:42 PM
Flojo's Avatar
Originally Posted by SCadaddle View Post
.. Tapping it on a wood block on the garage floor dislodged most of it in short order, however...
... however hitting the cooler is imho of no good for its structure
soak it and use airgun and you're good with no physical impact to it.
Old 08-29-2018, 12:04 AM
Targa_PB_78_SC
Good stuff, if not ants what about oil eating microbes? Nah ... too risky, what if they got in the tank
Old 08-29-2018, 04:39 AM
"There is definitely something relaxing cleaning grease off the old friend "
Hmmmmmm sounds a little weird to me.
Old 08-29-2018, 05:05 AM
Originally Posted by Bob Kontak View Post
This is just oil.
Have been using Awesome for years, incredible cleaner and cheap. I buy it a gallon at a time. Be careful and follow dilution recommendations, at full strength it can soften a varnish or lacquer wood finish and DON'T use it to wash your car!
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 08-29-2018, 06:56 AM
imaircooled's Avatar
an engine degreaser/cleaner that is safe to use while the engine is in the car works pretty well. Some agitation with a soft paintbrush helps too. I used the gunk brand but there are several brands available.
Looks good. Did you notice this helping with the temperature that your car runs on hot days?
Chris
Chris
1974 Porsche 911 Targa w/935 flat fan twin turbo motor, not really
"DTW" Dave W. "There is really not any such thing as a rebuild 'on the cheap' on a 2.7 motor. You'll either pay now, or you'll pay later, but you'll pay."
Old 08-31-2018, 08:03 AM
Chris
The car had been sitting for over a decade when I got it so I did this clean-up (along with cleaning the top of the engine and cooling fins) before driving it much. That said, with the oil cooler clean we never hit 250 on our trip from Arizona to Monterey for Werks Reunion and back. Stock 2.2L 911T we drove altitudes from sea-level to a 10,0000 foot mountain pass in Yosemite and ambient temps from 50º-115º F and the highest the oil temp ever reached was between the 210-250 marks when we were driving some uphill gradients around the Death Valley area between Beatty & Las Vegas with outside temps hovering around 110-115. Oil temp never actually reached 250 on the gauge.
Old 08-31-2018, 11:42 AM
