-   -   Anyone have a clever idea on fixing this? (http://forums.pelicanparts.com/porsche-911-technical-forum/1004399-anyone-have-clever-idea-fixing.html)
grant lyon 08-09-2018 11:03 PM
+1 on solvents esp acetone+ATF, heat. If you can access the other end (180° out) of the screw, you have many options including simple rocking twisting with visegrips. If u can't get drill to fit (parcel shelf?), try with 90° angle attachment. Last, worse/best: use a Dremel cut off wheel (incl 90 adapter as needed) to cut a straight screwdriver slot. Deepen with pointed carbide tip to get better purchase, then rock (twist) back and forth with stubby screwdriver. If you can't get a punch centered, at least a carefully cut slot gives you bit control on one in-plane axis.
http://forums.pelicanparts.com/uploa...1533880972.jpg
Bottom screw. Excuse LBC content.
Bob Kontak 08-10-2018 07:18 AM
Originally Posted by Steve F (Post 10134942)
Soak with PB blaster to start with for sure.
That was three days ago. I would hit it twice a day for a week.
Does not mean you can't start the easy outs, slots, etc. Just for putting some pressure on the mated surfaces that are corroded but I would wait a bit for the big turn.
Shorty62 08-11-2018 02:26 AM
And make sure your drill bit is bloody sharp and good quality.
