Air Medal or two
What dose M8 mean ??
in drivers door pillar near hinges by a small riveted plate ( that I believe is the paint code ? ) is the stamped raised "M8".....what dose that stand for ?? the car is a 1975 911 S ---thanks
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
Must be some production code for the pillar or assembly.
M8 means M=metric, 8=8mm diameter, 10=10mm diameter etc.
81 SC, www.frankschroeter.com |
My '72 has this as well. I think it's a subliminal suggestion to "mate".
Air Medal or two
.....I dont know if that's the meaning- not near bolts, not a part number for sure... its a raised part,,just above the door light switch. Made to be made noticed .
This came up in conversation with another P car owner yesterday.
Anyone know the answer?
'81 924 , '85 944 , '78 911SC , '82 928 5.0L "They run best being run close to the ‘limit’ and done so regularly" - Grady |
This is a rare code stamped by the only Australian to ever work on the Porsche production line - Kevin 'Kev' Davidson, referred to within the Porsche AG group as 'matey' for his jovial greetings to all and sundry.
If you remove your dashpad you'll find chalked underneath the words 'G'day' and 'struth - this is a bloody good car mate' True story :-) Told after a few beers...mate.
Earlysport _____________________________________ 69 911E, 69 911E RS Rep 3.0L Hotrod, 77 930 IROC REP 3.6L SOLD, 968CS SOLD, 987 Boxster S SOLD |
Almost Banned Once
It's on my 78 as well.
Hmmmm....
- Peter |
UNDER CONSTRUCTION!
i have always thought it to be a body code of sorts. kinda like the fox body cars and the a-bodys in the us type cars.
i have never looked at a pre 69 car to see if the code was different. now you have my curiosity. ed
Sometimes the first thing that comes to mind should be the last thing that you do!
Banned
Mine has it too. subliminally, right or wrong I always thought it was the size for the door hinge bolts....
Formerly reformed
1968 has it. The mystery deepens.
1968 911P (Paperweight) |
old thread alert
my assumption is. on early cars the counterplate for the hinge on the inside of the pillar is thinner(fact) and has different thread pitch 8x1?(guess). for more strenght they went for thicker plate and at the same time for M8(1,25pitch) thread. in order to avoid damage to the tread by useing the wrong thread bolts when repairs where carried out in the workshop(or even on the assambling line) they marked the new pillar version with M8. #300096 had damaged threads so are those on 450710(non M8 912) just guessing and could be all wrong update---had a look today at the undamaged threads on 450710 ...looks like i hit the nail |
Wer bremst verliert
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
I looked at a 68T (swb) today and the left side hinge pillar didn't have the M8 marking. What does this mean?
(I haven't checked right side hinge pillar unfortunately) |
