-   -   What’s this part? Engine tin or? (http://forums.pelicanparts.com/porsche-911-technical-forum/1004640-what-s-part-engine-tin.html)
Brian Cameron 08-10-2018 08:50 PM
Just installed my engine tin and can’t figure out where this bit goes... or is it even part of the engine tin or something else altogether?
http://forums.pelicanparts.com/uploa...1533959401.jpg
john walker's workshop 08-10-2018 09:35 PM
Used to be attached to the center engine mount console. There will be a bolt hole in the rear tin with no threads below.
Brian Cameron 08-10-2018 09:57 PM
Thanks John
Perfect, that’s it all right, you da man. As shown in foreground below...
http://forums.pelicanparts.com/uploa...1533963440.jpg
75 911s 08-11-2018 07:41 AM
I need two of these for my 3.2 carrier if anyone has these little tabs separate. There is one on each side correct?
Flat6pac 08-11-2018 05:51 PM
Well, believe it or not, the car will run without the pieces...
Bruce
