Earthling
What’s this part? Engine tin or?
Just installed my engine tin and can’t figure out where this bit goes... or is it even part of the engine tin or something else altogether?
1996 Porsche 993 C4. His 1979 Porsche 911SC - sold... and now BACK again! Hers 2021 Volvo V60 (foul weather drive) 2024 Volvo XC60 (spousemobile) |
Used to be attached to the center engine mount console. There will be a bolt hole in the rear tin with no threads below.
Earthling
Thanks John
Perfect, that’s it all right, you da man. As shown in foreground below...
Registered Minimalist
I need two of these for my 3.2 carrier if anyone has these little tabs separate. There is one on each side correct?
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
Well, believe it or not, the car will run without the pieces...
Bruce |
