My Custom Made Iozzio Classic Wheels.
Just thought I start a new thread in my One Off Custom made Wheels.
We are calling them Iozzio Classic Lightweights Can’t wait to get them. They should fit my project perfect. Specs are 18x7 with 5.5” backspacing 18x9.5” with 6.0” backspacing. http://forums.pelicanparts.com/uploa...1534013410.jpg http://forums.pelicanparts.com/uploa...1534013410.jpg http://forums.pelicanparts.com/uploa...1534012917.jpg http://forums.pelicanparts.com/uploa...1534013107.jpg http://forums.pelicanparts.com/uploa...1534013291.jpg |
Hmmm
Beautiful. Can't wait to see them mounted.
I soooo want some
They look great!
fronts are off a bit, they sit inboard too far for a 911 7 front you want ~4.79" of back space, which works out to be 7 ET24 what you really want for an SC/Carrera is 8 Et25-30 front and 90.5 ET19 rear |
http://forums.pelicanparts.com/uploa...1534035975.jpg |
Thank you very much guys. Can’t wait to get them mounted. Can’t really set up my suspension without the wheels. |
just FYI regular 911 Fuchs 7 w/ ET23.3 have ~4.77" backspace, your proposed wheel w/ 5.5" back space sit that much more inboard |
Curious about your choice of 18"? Not the typical fitment.
From my hub to the fender lip is 2.75 inches I gave myself a 1/4 gap for spacing non rolled front fender. That’s my “front spacing” subtract that from the overal 8” wheels size (lip to lip) and I have a back spacing of 5.5. There is no way I would be able to tuck a 7” wheel. 8” overal lip lip inside the fender with a 4.77 back spacing. That gives me a hub to outside lip spacing of 3.23. That’s outside my fender itself |
This is his test fitment wheel he brought over that is a 18x7 with 5.5 backspacing. http://forums.pelicanparts.com/uploa...1534041812.jpg
Holy cow they're nice wheels Jeremy!
I hate 15s. 16 and 17 don’t fill up the wheel arch very well IMO. 18s tuck nice, give the stance looks i am after. Huge tire selection at great prices. 19s have a limited tire options and more expensive. 20s just seem rediculess IMO. |
Wow..very cool! Looking forward to seeing them installed
Wow!
Hats off to you sir for doing your own thing. Love it!!!! Can’t wait to see how the car pans out when it’s finished. Looks like it going to be staggering! |
I have always been a fan of doing your own thing............ Well Done.
The largest wheel/tire is going to be 8ET25 225/45 x17, these have an OD of ~25", front space of ~3.44". These just barely clear a shaved lip when a little extra negative camber is used. The biggest tire on that wheel is a 235/45 x17 which requires the above + raised ride height. OD here is ~25.4" w/ f/s ~3.64". In summary f/s of ~2.95" is pretty comfortable but does require some car w/ tires( shorter being easier to fit) and possibly lips, ~3.5" is a max w/ height restrictions, the more under 3.5" the fewer height and suspension restrictions. |
With respect that’s great info for someone that’s running factory Fuchs. Thank you. However as you can tell these wheels are far from factory! I am VERY confident in my and the manufacturers measuring of offset to fit my set up. We have measured and measured for proper fitment for my car. I CANNOT fit a 3.5” front spacing within my fenders regardless if it’s trimmed or rolled unless I over roll the fender |
In fairness the car started out as s 912E. Could possibly change things. |
His posts are both accurate and cautionary. It implies that something may be out of spec on your car. Have you done an alignment prior to fitment? Do both sides measure out the same? BTW, nice looking wheel. |
I will report back when they are on.
Thanks for all the feed back guys it is appreciated. With regard to fitment. My fitment preference is not for track set up. The car will be much lower in stance then typically seen on this form. |
http://forums.pelicanparts.com/uploa...1534102752.jpg Look forward to seeing your progress. |
If that’s the hub to hub width my hub width isn’t anywhere near that narrow. Mine is 56-1/8” hub face to hub face. Both sides have a front hub to inside lip of fender is 2.75”. Everything seems true and straight |
it differs from hub to hub by 2x the wheel offset(ET), 6" Fuchs have ET36, this is positive in nature and so 72mm(~2.8") is added from the track to get the hub separation. |
so for the pictured car if 54.06" is the track 54.06 + 2.83 = 56.89" is the hub width I have amended this and my previous post, a negative o/s wheel will move the track width in while a positive o/s wheel(all Fuchs) move the track width out I n each case by 2xs the ET |
Thanks for all the great info.
What I do know is from my hub face to the inside lip of my none rolled fenders on both sides is 2.75”. And I subtracted 1/4” for clearance. |
positive o/s wheels move the track in by 2x the wheel ET. track - 2xET = hub width for 6" Fuchs w/ ET36 in the above diagram 54.06" - 2x36mm 54.06" - 72mm 54.06" - 2.83" 51.23" is the hub width |
Bill, i think your other measurements were correct. The WMS sits closer to the outside of the wheel on a positive offset wheel leaving the wheel centerline (track) inboard of the WMS. The hub to hub width is wider than the track width. .. |
positive ET wheels move the center line in from the hub so the wheel ET x2 need to be added to the track ti get the hub width. |
I hope it was a good bottle of wine. |
I'm confidant in the setup I wanted and what we measured too. If I was building a traditional car and setup I would be worried. However considering my car is VERY FAR from traditional I believe the way I had them built will more then satisfy me liking. Again thanks . Now I am going to wait patiently at the door for the mail man for my new wheels. :D |
Arrived and test fired. Absolutely nailed it and what I wanted. No way I could be anymore happy. :D:D:D
http://forums.pelicanparts.com/uploa...1534528691.jpg http://forums.pelicanparts.com/uploa...1534528691.jpg http://forums.pelicanparts.com/uploa...1534528833.jpg http://forums.pelicanparts.com/uploa...1534528833.jpg http://forums.pelicanparts.com/uploa...1534529061.jpg http://forums.pelicanparts.com/uploa...1534529061.jpg http://forums.pelicanparts.com/uploa...1534529061.jpg |
I think those look FANTASTIC! Looking forward to seeing them with tires and mounted.
Great job Jeremy
| All times are GMT -8. The time now is 02:51 AM. |
