-   -   Another H4 trim question (http://forums.pelicanparts.com/porsche-911-technical-forum/1004930-another-h4-trim-question.html)
acme911 08-14-2018 12:30 PM
Hi all,
Both of my H4 trim pieces look like the pic below. Should they have an exposed screw head? Am I correct in assuming that both trim pieces are missing the outer screws in the dual screw setup? I ask because want to take them off and affix them correctly.
http://forums.pelicanparts.com/uploa...1534274730.JPG
Bill Verburg 08-14-2018 04:12 PM
Originally Posted by acme911 (Post 10142773)
Hi all,
Yes, the factory used these 2 screws, an inner and outer, w/ plastic washers
http://forums.pelicanparts.com/uploa...1534288177.JPG
the thread is M5 -.8 thread pitch
as an alternative you can get a couple of button head M5 -.8 bolts ~20-25mm long and a plastic washer. The Hex head makes it easy to use a wobble key. This makes it easier to snug up than w/ a screwdriver.
acme911 08-14-2018 04:20 PM
Thanks Bill. I’m big fan of button head screws and bolts. I like your idea.
