-   -   Third number on engine case (http://forums.pelicanparts.com/porsche-911-technical-forum/100507-third-number-engine-case.html)
Targa68 09-04-2013 10:12 AM
Looking for this engine and trans. lost it in 1979. Just purchased #3281590 last night.http://forums.pelicanparts.com/uploa...1378318341.jpg
billh1963 09-12-2014 03:23 PM
engine serial number 901561, build number 1461
porsche91490101 09-26-2014 05:14 PM
901/01
Don't know if your still keeping a register but i have a 2.0L Porsche engine Type 901/01 with Serial # 902862 Build # 2762.
djpateman 02-21-2015 06:07 PM
Yes, I keep checking and adding to my database.
Flat6pac 11-09-2015 05:28 PM
68 L aluminum cast case
Had aluminum chain boxes and 68 casting numbers on the cam carrier with 11 nut exhaust valve covers.
Was in my possession for a short time
Bruce
http://forums.pelicanparts.com/uploa...1447122428.jpg
http://forums.pelicanparts.com/uploa...1447122445.jpg
djpateman 11-10-2015 03:33 AM
Thanks Bruce, every datapoint helps. Dave
group911@aol.co 11-10-2015 06:00 AM
Dave
Can't remember if I sent you this one. Tell me about it. http://forums.pelicanparts.com/uploa...1447167536.jpg
http://forums.pelicanparts.com/uploa...1447167596.jpg
http://forums.pelicanparts.com/uploa...1447167611.jpg
group911@aol.co 11-10-2015 06:02 AM
http://forums.pelicanparts.com/uploa...1447167739.jpg
djpateman 11-10-2015 08:32 AM
Bob, that is very interesting. I had the VIN & engine # but that was it.
Nice to confirm the build # with a photo.
The AC installation is very unusual. Would probably be worth getting the Kardex; contact me please.
frank edwards 11-17-2015 06:05 PM
vin and production numbers
hi dave,good to see your still working on your data base,haven't heard from you since last sept,when i sent you pictures of production and vin#s,just wondering if your contacts or data base had yielded the missing vin number,best,SmileWavy frank.
Marken 12-02-2015 05:24 PM
I have some engine info:
Number 907303
Type 901/05
Build 4159
Is it a '66?
Thanks,
Kevin
l.a.brooks 01-10-2016 06:54 PM
couple more numbers
2081572 901/03 15477
4080375 901/02 10604
KimK 01-14-2017 03:37 AM
901/14 case no
901/14 11188 blank case - aluminium
901/14 10665 3230302 - aluminium
both engines without cars in the moment
KimK 01-14-2017 04:28 AM
901/14 case no
901/14 10665 3280302 - aluminium
djpateman 01-15-2017 06:05 AM
Kevin, definitely a 1966 Model Year
Larry, thanks!
Kim, 11188 should not be blank; is there evidence of the serial being removed?
The original serial is likely near 3280433 +3/-7
ksjackam1865 02-25-2017 10:07 AM
Originally Posted by djpateman (Post 4027805)
http://forums.pelicanparts.com/uploa...1214593533.jpg
This image provided by Bob Fleming shows the three engine #'s seen on the 2.0 motors. The engine serial # is bounded by stars, the engine type # is 901/xx, and the engine build # runs from 1 to about 30000.
The build # is simply the build sequence number from the engine shop. For the early 901/01 engines it was 100 less than the serial # since the production engine numbers started at 900101. As new engine types were added there was no relationship to the engine serial #. Here is some of the the data I have collected:
901/01 900128 28
901/01 900129 29
901/01 900236 136
901/01 900661 561
901/01 900685 585
901/01 901109 1009
901/01 901363 1263
901/01 901449 1349
901/01 901467 1367
901/01 901954 1854
901/01 902016 1916
901/01 902409 2309
901/01 902461 2361
901/01 902562 2462
901/01 902589 2489
901/01 902628 2528
901/01 903022 2922
901/01 903154 3054
901/01 903256 3156
901/02 960151 3584
901/20 906106 3629
901/05 907041 3879
901/05 907059 3900
901/20 906137 3979
901/05 907137 3984
901/05 907183 4036
901/05 907203 4056
901/05 907316 4172
901/05 907540 4405
901/05 907609 4474
901/05 907849 4714
901/05 908164 5032
901/05 909136 5189
901/05 909445 5703
901/02 960306 5873
901/02 960375 5998
901/02 960377 6010
901/02 960407 6052
901/05 909857 6099
901/02 960492 6225
901/05 909914 6697
901/02 960841 6821
901/02 960913 6895
901/02 960927 6925
901/02 961030 7150
901/02 961095 7240
901/06 ______ 7269
901/02 961208 7464
901/06 911305 7558
901/02 961390 7782
901/02 961687 8316
901/06 911718 8504
901/02 961942 8744
901/02 962082 8987
901/06 911951 9044
901/02 4080029 9272
901/06 3080031 9277
901/02 4080111 9423
901/02 _______ 9525
901/03 2080005 9547
901/14 3280123 9874
901/07 3180047 9906
901/14 3280234 10234
901/17 _______ 10584
901/06 _______ 10743
901/02 4080430 10923
901/14 3280376 10958
901/14 3280442 11233
901/14 3280461 11397
901/14 3280529 11677
901/03 2080552 11710
901/14 3280620 12050
901/14 3280670 12194
901/14 3280822 12976
901/02 4080919 12986
901/17 3380223 13016
901/02 4080941 13108
901/14 3280920 13393
901/02 4081110 13965
901/17 3380303 14124
901/02 4081172 14233
901/14 3281356 15372
901/06 _______ 15373
901/02 4081419 15415
901/02 4081449 15552
901/14 _______ 15841
901/17 3380402 16015
901/10 6390001 16250
901/10 6390050 16339
901/10 6390067 16410
901/16 6195052 16416
901/16 _______ 18638
901/16 6195563 19205
901/09 _______ 19692
901/16 6195715 19789
901/16 6195728 19821
901/03 6190553 19846
901/10 6391067 20928
901/09 6291062 21168
901/09 6291092 21324
901/10 6391343 22398
901/10 6391344 22399
901/10 6391515 23256
901/10 6392102 26274
Everyone that has a 2.0 motor with any 901/xx engine type is encouraged to contribute their combination of 3 codes to my list. We can learn a lot about how these engines were built. It seems to apply until the end of 1969 model year, then it was discontinued.
Dave
http://forums.pelicanparts.com/uploa...1488049486.jpg
356RS 02-25-2017 10:26 AM
Dave, I though I gave you my info before but I don't see it on your list. Eng s/n 6392032 type 901/10 build # 25955
Mark
Targa68 03-11-2017 07:03 AM
http://forums.pelicanparts.com/uploa...1489248209.jpg
alfy 09-19-2018 10:21 PM
Hi
I bought a 1968 2 liter yesterday here in Norway. Used to be in an old VW bus some years:D
Type 901/03 with Serial # 2080404 Build # 11028
http://forums.pelicanparts.com/uploa...1537424371.jpg
djpateman 09-20-2018 10:28 AM
Thanks guys. Just a reminder that the most up to date list is found here; I can update this thread easier since Pelican posts cannot be updated a after a short period. When possible please look for the case mating #,s on the top of the case near midpoint, and the casting dates under the pulley on each half.
Type 901/xx Engine Build #'s
HM1313 04-28-2024 01:26 PM
1967 911s stamp
I'm looking to purchase a 1967s. This is engine stamp. Car comes with Kardex. Just wanted to triple check with the experts here. Thanks so much!http://forums.pelicanparts.com/uploa...1714339597.png
