Budget front oil cooler install using Carrera cooler lines???
I remember somewhere reading a thread where somebody recommended splicing Carrera oil cooler lines, and somehow attaching those to 16AN lines to run to a front oil cooler. The purpose being to avoid using expensive adapters. I can't find the article now.
Whoever is familiar with how to do this, could you please chime in? I have the RS bumper on, the Setrab cooler on its way, and need to start running the lines. Thanks! Colby |
Bump..someone has to know.
I think I heard that Chuck at elephant sells direct adapters or something??
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
He does... at $80 for the pair. Not horribly expensive, but not cheap. Just curious as to any cheaper means, especially since someone had mentioned it in the past.
Colby |
Pegasus racing has adapters as well - for about $44 or so each, so you're better off getting them from Chuck.
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
