-   -   Need conversion advice Has anyone done a 3.0 to 3.2 succesfully (http://forums.pelicanparts.com/porsche-911-technical-forum/100538-need-conversion-advice-has-anyone-done-3-0-3-2-succesfully.html)
Norm Faustino 03-03-2003 08:21 PM
I am looking to rebuild my 3 liter 78 sc and I have come across a set of 3.2 P's & C's real cheap so I might as well do the upgrade but I need to know if the wrist pins and the heads and crank from the 3.0 are compatible with the 3.2 or do I have to do anything else to it? If anyone has done one of these successfully please impart your wisdom and thoughts about this to me. all is appreciated.
thanks,
Norm
:confused:
CamB 03-03-2003 10:14 PM
You mean like as in 3.2 Carrera P&C???
They are the same bore as a 3.0, but designed for a different (longer stroke) crank - hence difference in capacity.
Or are they REALLY cheap, and you already know what I just said?
Norm Faustino 03-03-2003 10:25 PM
I can get them for 500.00 so I guess thats cheap
CamB 03-03-2003 10:30 PM
Yeah, but it isn't really an upgrade - it won't make the engine any bigger (and you might have trouble with high compression).
emcon5 03-03-2003 11:21 PM
And the wrist pins are the wrong size.
2 ways to make a 3.0 into a 3.2, larger bore, (98mm P&C's designed for a SC engine) or longer stroke (crankshaft from a 3.2 Carrera). Unfortunately neither is inexpensive.
Tom
