Norm Faustino's Avatar
Need conversion advice Has anyone done a 3.0 to 3.2 succesfully
I am looking to rebuild my 3 liter 78 sc and I have come across a set of 3.2 P's & C's real cheap so I might as well do the upgrade but I need to know if the wrist pins and the heads and crank from the 3.0 are compatible with the 3.2 or do I have to do anything else to it? If anyone has done one of these successfully please impart your wisdom and thoughts about this to me. all is appreciated.
thanks,
Norm
78 911 SC "Scratchy"
2004 Mini Cooper S "Pele" (gone but not forgotten)
1979 classic mini clubman-"Coolio"
Old 03-03-2003, 08:21 PM
CamB's Avatar
You mean like as in 3.2 Carrera P&C???
They are the same bore as a 3.0, but designed for a different (longer stroke) crank - hence difference in capacity.
Or are they REALLY cheap, and you already know what I just said?
1975 911S (in bits)
1969 911T (goes, but need fettling)
1973 BMW 2002tii (in bits, now with turbo)
Old 03-03-2003, 10:14 PM
I can get them for 500.00 so I guess thats cheap
Old 03-03-2003, 10:25 PM
CamB's Avatar
Yeah, but it isn't really an upgrade - it won't make the engine any bigger (and you might have trouble with high compression).
1975 911S (in bits)
Old 03-03-2003, 10:30 PM
Hilbilly Deluxe
emcon5's Avatar
And the wrist pins are the wrong size.
2 ways to make a 3.0 into a 3.2, larger bore, (98mm P&C's designed for a SC engine) or longer stroke (crankshaft from a 3.2 Carrera). Unfortunately neither is inexpensive.
Tom
82 911SC Coupe
GTI Cup #43
Old 03-03-2003, 11:21 PM
