-   -   trying to find color number (http://forums.pelicanparts.com/porsche-911-technical-forum/1005491-trying-find-color-number.html)
robertmark 08-20-2018 01:23 PM
Is this the right forum to ask where the color code is located on a 1969 911E? Is it on the stainless piece under front hood with vin and reads Dr. Ing Ferry Porsche? thanks in advance
geoff_68s 08-20-2018 11:28 PM
It should be stamped on a smallish metal tag that's riveted to the front of the drivers side door jamb, below the light switch and above the check rod.
robertmark 08-21-2018 05:45 AM
Thanks, I'll get looking!!
HarryD 08-21-2018 04:11 PM
This is the tag you are looking for (from another persons post):
Originally Posted by earlyaircooled (Post 5405340)
robertmark 08-22-2018 06:07 AM
Found it. Metallic Green. The number above it I presume is the body Number? My paint code is stamped in very bold, the other number I can't even see a trace. One owner car, never painted or had this plate removed. Why is there no number there? Also, what does M8 represent. Thanks guys!!!!http://forums.pelicanparts.com/uploa...1534943140.jpg
HarryD 08-22-2018 06:25 AM
No one be the deal with the “M8”. It is a mystery.
Please post a picture of the plate.
robertmark 08-22-2018 06:28 AM
plate pic
Here is the plate. M8 is stamped into body above this. http://forums.pelicanparts.com/uploa...1534944514.jpg
HarryD 08-22-2018 08:37 AM
The L at the end indicates the paint was made by Lesonal
You can look at colors here : https://members.rennlist.com/tweedt/glasurit.htm
djpateman 08-22-2018 08:43 AM
From 1969 the VIN was not stamped on the paint badge.
The L on the paint code is for Lesonal, the paint supplier.
The M8 may be related to the bolt thread size of the hinge bolts, but why is not known.
