VDO cd716u-bu radio aux input
I purchased this radio thinking it had Bluetooth. It doesn't
It has a 3.5 input off back of radio. I tried to stream music from my phone via this input. I could not get it to work.
Does anyone know if it should?
Old 08-31-2018, 03:35 AM
Runnin on empty
acme911's Avatar
I looked over the PDF manual. You are correct, there is no Bluetooth. As for Aux in. You should be able to select it via the SRC( source) button.
https://www.peerlesselectronics.com//files/CD716U-BU.pdf
If you want Bluetooth streaming and phone capabilities may I suggest TranzitBlu.
https://www.amazon.com/s/?ie=UTF8&keywords=tranzit+blu+hf+isfm2351&tag=googhydr-20&index=aps&hvadid=234300464760&hvpos=1t1&hvnetw=g&hvrand=79707777445604287&hvpone=&hvptwo=&hvqmt=b&hvdev=t&hvdvcmdl=&hvlocint=&hvlocphy=9031879&hvtargid=kwd-73287385004&ref=pd_sl_60t0k5ybv7_b
'74 911, Steel Wide Body Hotrod, 3.0, Jenvey ITB’s, AEM Infinity, KW V3's, Eibach Sways, JWest shifter and other stuff.
https://forums.pelicanparts.com/porsche-911-technical-forum/1006126-midi-modded-bumpers-led-headlight-manifold.html
Old 08-31-2018, 05:49 AM
Figured out I can use the two rca inputs. Found a rca to 3.5mm cord. Can now stream music from my phone.
Old 09-03-2018, 03:52 PM
