need help: 3 litre SC engine - should I go for carbs, efi or whatever?
What would be the best option, not the most expensive one?
rebuild engine, SSI, lighter flywheel .. is there a comparison somewhere? thanks! |
I'm interested in this question as well. Have a 3.0L SC and thinking either rebuild to something with more displacement and power ~300+ hp or just swap the engine to a 964 3.6L and start from there or be happy with the ~250hp which will probably feel more than adequate in my 75 911S.
regarding the fact, that to nicely tune up a 3.0 you have to split it (for e.g. S-cams, JE-pistons, 993-pump, etc.), either if it's a Max&Moritz upgrade oder bore-up to a 3.2... this cost money.
And as far as I know it cost way more money than to swap for a larger/later engine. The average price for solid a 3.2 upgrade is between €17.000-20.000 I'd not spend that money vs a good 3.6 correct me if I'm wrong |
964 cams, SSI exhaust, remove some weight.
Speed costs money.........
engine is sound and trans rebuilt. I read about a + of 40hp (SSI, 964 cams 20/21 and 9,3/9,8 pistons)... true? |
If you've got the $, the above + ITB's. More power, better drive-ability, better fuel economy, killer look and the carb'd sound... no brainer |
My mechanic has given me this estimate of what it would look like to do a 3.0L rebuild with upgrades to get over 300hp. Anyone able to comment on whether this seems reasonable? This does not include a separate estimate of ~$6k for headers and muffler. In addition to this I am assuming I will need a front corner oil cooler to fit under the early 930 front valence which I would estimate as a $3k job. So by this standard I'm looking at an estimate of ~$27k....and I always assume there will be something new to add as the work begins. Still have not pulled the trigger on this as I may be able to get a freshly rebuilt 964 3.6 engine instead for around $19k
http://forums.pelicanparts.com/uploa...1535719819.jpg |
Wouldn't this also require another cost item to get all this work work properly, not just the adding parts and rebuilding ? What compression would you be going for to hit 300 hp, that seems like a very difficult number to hit.
I have lightened flywheel and clutch in both of my cars. They work just fine, you don't even notice the difference taking off from a stop. You do notice the engine revs quicker. And I think you could do the Triumph ITB for a little more than the Carbs with better performance when done. |
The 74 RSR was 226 and the 84 SCRS was 247 probably using racing gas. In the countless hours burned on this forum, I have not seen normally aspirated 3.0 dyno graphs that demonstrate 300hp. Guessing it's been done but you would really have to have a screaming spinner that would require special rods and retainers on top of the other goodies. Also, a high performance oil pump and other oiling tricks. If I am full of wind and you can get 300hp, I don't think you would like it. |
http://forums.pelicanparts.com/uploa...1535725123.jpg
Here is my SC engine entirely rebuilt into a 3.2 short stroke, new everything, upgraded rods, valve train etc. 10.5:1, twin plug, and high butterfly intake with coil on plug EFI. No dyno yet, as it is just being completed. Cost? Don't expect $25k to cover it. |
What concerns me about the estimate I've been given is the use of the words 'custom' and 'special' numerous times without a good explanation of what that means. The only thing that is detailed extremely clearly is the amount of $$ I'll be shelling out. I will be requesting a lot more detail before signing on to the build.
[QUOTE=1979-930;10163334]Not true. It's just something that people repeat because they heard it one time.
I have lightened flywheel and clutch in both of my cars. They work just fine, you don't even notice the difference taking off from a stop. You do notice the engine revs quicker. https://mechanics.stackexchange.com/questions/28561/what-are-the-benefits-of-a-lightweight-flywheel-and-why-arent-they-lightweight Please don’t assume that I’m just repeating something. Hey, whatever works for you. |
Seems awfully inexpensive :eek: Be careful, because once you see half an estimate like this one, you'll give the go ahead to tear the motor apart...then you're committed, and when the finished product has a $35k price tag you're not going to be too happy. Anyone here can tell you, $17.5 is about the halfway point to a 300hp 3.0L |
That write up is a joke. But it's on the internet, so it must be fact. |
| All times are GMT -8. The time now is 10:04 PM. |
