-   -   need help: 3 litre SC engine - should I go for carbs, efi or whatever? (http://forums.pelicanparts.com/porsche-911-technical-forum/1006483-need-help-3-litre-sc-engine-should-i-go-carbs-efi-whatever.html)
ixxified 08-31-2018 04:26 AM
What would be the best option, not the most expensive one?
rebuild engine, SSI, lighter flywheel ..
is there a comparison somewhere? thanks!
plexiform 08-31-2018 04:32 AM
I'm interested in this question as well. Have a 3.0L SC and thinking either rebuild to something with more displacement and power ~300+ hp or just swap the engine to a 964 3.6L and start from there or be happy with the ~250hp which will probably feel more than adequate in my 75 911S.
Flojo 08-31-2018 04:42 AM
regarding the fact, that to nicely tune up a 3.0 you have to split it (for e.g. S-cams, JE-pistons, 993-pump, etc.), either if it's a Max&Moritz upgrade oder bore-up to a 3.2... this cost money.
And as far as I know it cost way more money than to swap for a larger/later engine.
The average price for solid a 3.2 upgrade is between €17.000-20.000
I'd not spend that money vs a good 3.6
correct me if I'm wrong
BK911 08-31-2018 04:58 AM
964 cams, SSI exhaust, remove some weight.
fred cook 08-31-2018 05:04 AM
Speed costs money.........
how fast do you want to go? A typical rebuild with some hot rod upgrades will cost about $10 -$12,000 in parts plus labor. A rebuild done at a good shop will be about $20 - $25K out the door. There are some less expensive things that can be done. Change over to the SSI exhausts for about $2K. Replace the clutch cover with the aluminum one for lower weight and faster revs, about $1K. Change camshafts to 964 cams for a couple of thousand dollars. Have an expert go thru the CIS and make certain it is working "just right", a few hundred dollars. Basic tune up, distributor cap, rotor, plug wires and plugs, again, a couple hundred dollars. If your engine doesn't have any broken cylinder head studs or weak cylinder compression and has good oil pressure, I would leave it alone. Drive it long enough and some or all of the above mentioned problems will show up. That will be the time for a major rebuild. In the end, it is your car and money, make it just the way you want it to be! Happy motoring.
Flojo 08-31-2018 05:36 AM
I did SSI and weight reduction.
engine is sound and trans rebuilt.
I read about a + of 40hp (SSI, 964 cams 20/21 and 9,3/9,8 pistons)... true?
911SauCy 08-31-2018 05:55 AM
From bone stock US Spec motor, I would totally believe that. But I would also imagine that's about the limit without fuel injected ITBs
If you've got the $, the above + ITB's. More power, better drive-ability, better fuel economy, killer look and the carb'd sound... no brainer
plexiform 08-31-2018 05:56 AM
My mechanic has given me this estimate of what it would look like to do a 3.0L rebuild with upgrades to get over 300hp. Anyone able to comment on whether this seems reasonable? This does not include a separate estimate of ~$6k for headers and muffler. In addition to this I am assuming I will need a front corner oil cooler to fit under the early 930 front valence which I would estimate as a $3k job. So by this standard I'm looking at an estimate of ~$27k....and I always assume there will be something new to add as the work begins. Still have not pulled the trigger on this as I may be able to get a freshly rebuilt 964 3.6 engine instead for around $19k
http://forums.pelicanparts.com/uploa...1535719819.jpg
acme911 08-31-2018 06:32 AM
Hi, I have a ‘74 with an ‘82 3.0. First take the weight out. Second, if motor is strong, get ITB’s, modern ECU system, exhaust. Third, take the rest of your money and spend it on other parts of the car or better yet, by some more toys.
acme911 08-31-2018 06:37 AM
Light flywheel is for racing. Not recommended for everyday driving.
Jesse16 08-31-2018 06:50 AM
Wouldn't this also require another cost item to get all this work work properly, not just the adding parts and rebuilding ? What compression would you be going for to hit 300 hp, that seems like a very difficult number to hit.
1979-930 08-31-2018 06:59 AM
Not true. It's just something that people repeat because they heard it one time.
I have lightened flywheel and clutch in both of my cars. They work just fine, you don't even notice the difference taking off from a stop. You do notice the engine revs quicker.
And I think you could do the Triumph ITB for a little more than the Carbs with better performance when done.
Bob Kontak 08-31-2018 07:08 AM
I am not convinced that build sheet reflects 300 hp.
The 74 RSR was 226 and the 84 SCRS was 247 probably using racing gas.
In the countless hours burned on this forum, I have not seen normally aspirated 3.0 dyno graphs that demonstrate 300hp.
Guessing it's been done but you would really have to have a screaming spinner that would require special rods and retainers on top of the other goodies. Also, a high performance oil pump and other oiling tricks.
If I am full of wind and you can get 300hp, I don't think you would like it.
David 23 08-31-2018 07:23 AM
http://forums.pelicanparts.com/uploa...1535725123.jpg
Here is my SC engine entirely rebuilt into a 3.2 short stroke, new everything, upgraded rods, valve train etc. 10.5:1, twin plug, and high butterfly intake with coil on plug EFI. No dyno yet, as it is just being completed. Cost? Don't expect $25k to cover it.
plexiform 08-31-2018 07:25 AM
What concerns me about the estimate I've been given is the use of the words 'custom' and 'special' numerous times without a good explanation of what that means. The only thing that is detailed extremely clearly is the amount of $$ I'll be shelling out. I will be requesting a lot more detail before signing on to the build.
acme911 08-31-2018 07:31 AM
[QUOTE=1979-930;10163334]Not true. It's just something that people repeat because they heard it one time.
https://mechanics.stackexchange.com/questions/28561/what-are-the-benefits-of-a-lightweight-flywheel-and-why-arent-they-lightweight
Please don’t assume that I’m just repeating something.
Hey, whatever works for you.
911SauCy 08-31-2018 07:32 AM
That estimate dated 2008?
Seems awfully inexpensive :eek:
Be careful, because once you see half an estimate like this one, you'll give the go ahead to tear the motor apart...then you're committed, and when the finished product has a $35k price tag you're not going to be too happy.
Anyone here can tell you, $17.5 is about the halfway point to a 300hp 3.0L
plexiform 08-31-2018 07:32 AM
That is a nice looking engine! Where did you have it built?
1979-930 08-31-2018 07:44 AM
Until you own and drive a car with a lightened flywheel; You are just repeating something.
That write up is a joke.
But it's on the internet, so it must be fact.
David 23 08-31-2018 07:45 AM
Rasant Products in SoCal built the engine. Andrew is very highly respected builder and designer of engine management systems. The intake system was put together by Marc Zurlinden at Revival Road in Monterey. He and Andrew worked closely together to create the completed engine.
Geronimo 08-31-2018 07:48 AM
LS swap 500HP might be lighter, and half the cost. ;)
markhoward 08-31-2018 08:01 AM
Did my 78 SC a couple years ago and just hit 20k. Stock CIS, 95mm 9.5/1 JE's, Elgin 'Super SC' grind (middle ground between stock and 964) and SSI's. Overall, I like the combo but if I had to do it again, would go 98mm Max Moritz style pistons. Reason being it wants to detonate at the top of the RPM range on 91 octane when timed to spec. Have really cold plugs which helps. Sometimes I mix in a bit of 100 unleaded netting about 93. MM would have cost about double of JE + replated barrels but in hindsight, totally worth it..
pkabush 08-31-2018 08:31 AM
There’s a 3.6 posted now for what seems a very good price. IIRC $14,500 but even if you get a decent 3.6 for $15-$20,000 you’re taking a gamble installing it without freshening it up. And, you’re a long ways from being done financially. It costs a lot of $ to do a proper 3.6 swap.
Personally, I’d way rather have a lightened 911 with a hot 3.0
Another option would be to get a 3.2 and turbo it. If done correctly they can make huge power reliably.
LakeCleElum 08-31-2018 08:59 AM
I have a engine in my 73.5 with these mods and running CIS:
1) Max Moritz 3.2 liter pistons and cylinders, 2) 964 cams, 3) Raceware hardware, balanced rods, Carrera oil pump. New parts included: intake valve sleeves, rod bearings and rods balanced, and rocker arms. Transmission clutch disk, pilot bearing and fork were replaced. Early Exhaust.
HP is 209 at rear wheels. Maybe 235-240 at Crank? I think 300 hp is a reach as Bob K said...
QueWhy 08-31-2018 09:47 AM
Sorry, to get my $17,800 for anything you are going to have to do better than a single handwritten sheet with vague descriptions and round numbers. I'd want part numbers, specs, labor rates, estimated time to completion, etc, etc, etc. Plus, I don't see 300hp coming out of that engine. What 3.0 do you have? If you want 300hp just slap on a turbo, keep turning up the boost until you get to 300, when it blows up then worry about whether to rebuild or swap a 3.6.
MichaelSJackson 08-31-2018 10:09 AM
ixxified,
Seems they ran away with your thread?
In the US, the 3.0 CIS engines were crippled making a first attempt at smog control.
First things first. Replace the exhaust. It was all channeled over to one side. Either get tuned headers or if you still want a heater get SSIs. You'll get 17-20 hp immediately. If you don't fix the exhaust first, then it will prevent any other upgrades from producing the desired improvement they should.
Secondly, replace the CIS. The CIS is sensitive to blow-back from aggressive cams. So your choice of better cams is limited by the CIS. I've found the CIS to be very dependable but it cannot be re-mapped. You can't change the carbs jets or the fuel injection's map. Simplest, wonderful solution is to replace the CIS with 6 PMOs. Put your foot into it and you'll hear Banchees wailing at you from behind! I chose to go the EFI route instead (Bitz kit). I'm happy, but I feel it was a lot harder to learn all the new stuff.
Thirdly, pick a new set of cams. At least something more aggressive than the CIS would have allowed. At this point you'll have the engine that the SC should have come with from the factory.
Each of those could have been done as individual projects or you could do them all at once. Of course there is a lot more that could be done, but it's a start.
Borrow a copy of Bruce Anderson's 911 Performance Handbook and read the section on SCs.
Michael S. Jackson
'78 SC w/Bitz
pmax 08-31-2018 10:19 AM
3.6 is extra weight as well.
Don't neglect the poor 915 on your road to 300hp.
Jonny042 08-31-2018 10:21 AM
Hope you are able to share some dyno results in the future, I'm sure many would be interested. Should be 300hp if it's a streetable setup, maybe more if it's on the racier side?
plexiform 08-31-2018 10:33 AM
Apologies to to OP. Didn’t mean to hijack your thread. Seems like we are considering similar ideas. Just sharing what I have learned.
QueWhy: Yes I agree, the handwritten vague estimate gives me no confidence.
Geronimo 08-31-2018 10:36 AM
Define your budget and your goals...
For 300hp I think you're looking a budget at least the value of your car... maybe more.
Think of it this way, Porsche didn't ever try to make NA power from their engines... they gave up and slapped a turbo on them.
The 3.6L swaps used to be worth while... but with engines going for 14-18K used, with another 10-12K+ in freshening costs you have a huge bill for what is really a small jump in power.
From my research being in a similar place I think a fresh build with hot cams and carbs or ITB headers and good ignition you'll have a fun very responsive engine... get the car down to 2200lbs and your power to weight will be very good and give your faster than stock 3.3 turbo acceleration
QueWhy 08-31-2018 11:13 AM
Originally Posted by MichaelSJackson (Post 10163607)
ixxified,
Michael S. Jackson
'78 SC w/Bitz
Whoops I thought plexiform was the OP.
Ixxifield, absolutely do the SSI/header and exhaust(provided you don't live in CA ) first. I just installed SSIs and an M&K muffler on my 3.0 SC. Results are way better than I expected. I think the 17-20hp figure in the post I quoted is based on an assumption and actual gains may be less. Personally I don't care if I gained 1hp or 100, the car is way more fun to drive and listen to, I saved some weight from rear of the car and it looks much better. For about $2000 including heat backdate my only regret is not doing it sooner.
Geronimo 08-31-2018 12:34 PM
I think the key to 3L power is getting a nice loud exhaust and enjoying the sound, while accepting you will not get HP out of a 3L without a HUGE amount of cash.
I'm beginning to accept that my Porsche is a very expensive Miata from Germany. :)
targa72e 08-31-2018 01:06 PM
Couple thoughts on 300HP 3.0L SC engine.
First what RPM does it take?
Since Torque in a normally aspirated engine is very tightly tied to displacement to get more HP requires more RPM. lets assume our well tuned 3.0 L that has around 200Ft/lb of torque you need that at about 8000 RPM ((RPM * T) / 5252=HP) not very streetable as the cams to get you 8000 RPM will not make much low end torque. So if we want to increase torque we make the engine bigger, say 3.5L , we don't need as much RPM. So we get a 74.4MM stroke crank and 100MM P&C and assuming the torque increase from displacement gets us to 233FT/LB we now only need that at 6900RPM which is a little more streetable but still a big jump from the 4500K torque peak on a stock SC.
john
Trackrash 08-31-2018 02:13 PM
There are a couple of books out there that detail many options. Bruce Anderson's Porsche 911 Performance Handbook and Wayne's How to Rebuild and Modify Porsche 911 engines. Good reading and informative.
There also have been many build threads here over the years. Maybe some here can offer some links.
An exhaust backdate, SSI, and a re-tuning of the CIS can make for a fun car, if you reduce your weight. Then add carbs for a little more umph. The next step is different pistons and cams. That is the best bang for the buck, IMO. After that the sky is the limit.
As far as light flywheels go, that also comes in degrees. The stock SC flywheel is already very light. If you have one of the aluminum pressure plates you will have all the response you want. I doubt you would notice the difference with a pound or two removed from the stock SC flywheel. On the other hand if you go with an aluminum flywheel, you may not be happy with the way it drives.
Geronimo 08-31-2018 03:38 PM
Just thinking out loud here as it addresses the question at hand...
So say you have SSI, Carbs, weight down under 2300#, added cams, ... whats the next logical step... twin plug heads? 10:1 comp? swap to large port heads or port work?
I think the sweet spot is SSI, Carbs, Cams, and maybe a comp bump... get the car under 2300#
Wondering where the smart money is.... I think spending 25-35K on a 250HP motor is just plain stupid, unless your a doctor or a lawyer and 35K is chump change. ;)
Maybe i'm in the minority here under a quarter million a year. :D
David 23 08-31-2018 05:20 PM
I don't think it has to do with the amount of money one makes, I believe it is more about how one wants to enjoy whatever that amount is. Priorities are different for everyone, that fact doesn't make some people stupid.
Geronimo 08-31-2018 05:40 PM
I get that, but it's from my perspective. If 35K was a monthly income I might not care about dropping that on an engine... alas I am neither smart nor talented so my means are limited.
The fact that I was able to get a 911 at all is amazing to me.
I still think 35K for a Porsche engine is insane, I mean they haven't change in 40 years the tools should be more than paid for right, same goes for pistons right.... I would love to understand the price structure of a 6K set of P&C's But it is what it is, so if you want to play you have to pay and if I was wealthy I would,I might grimace but i'd still pay it. LOL
But back to topic, I think if money is an object, a smart build might be carbs/ITB, SSI, Cams, and maybe a compression bump with ignition, then drop that weight... the rest spend on suspension bits.
fintstone 09-01-2018 07:16 AM
If my mechanic gave me that list purporting to get 300hp on street gas from a 3.0, I would find a new mechanic. 250 would be a stretch. That last 50-75 hp are the hardest.
fintstone 09-01-2018 07:44 AM
For what it is worth, this is what Supertec put into the 3.0 in my '74 targa (with S options: gauges, brakes, and shocks/struts, etc.). Execution is as important in a rebuild as much as great parts...and Supertec was considered the best builder the game by many (I hauled my car crosscountry on a trailer to ensure that some local dumbass didn't have to learn on my car). I told them that I wanted a 3.0 engine for the street that would give me 10 years and 100k miles (minimum) on street gas. Very drivable, but one that sounded and felt kill my '74 2.7 (just faster and with more torque). This is what we came up with (and the kind of detail that your mechanic should be giving you before you make any decisions):
From the build sheet:
Engine, new JE Pistons/Mahle cyl.,9.5
WebCams 20/21
clutch
resurfaced flywheel
rebuilt distributor
New permatune
rebuilt alternator
high torque starter
Oil Pump, modified for increased flow
mag, polish, balance crank
bal rods, pistons,pulley
new valve guides/valves
49 in, 41 exhaust ports 39 in, 38 exhaust
turbo valve covers
carrera tensioners
new chains
SSIs, early SS muffler
rings
bearings
Supertec head studs
Carerra Oil Cooler and Fan
No smog, oxygen sensor, etc.
The shop was pretty surprised at how fast the car was...likely because it had 15 inch wheels and 7:31 gearing. They estimated close to 250 hp...but I never dynoed. They used a '78 top end for bigger manifold runners and increased the size of the valves...and an '82 bottom for increased compression. The car is very fast and revs very well, pulling hard to redline. It is the fastest 3.0 that i have driven...by far (including carbed models)....I did eventually go back and update my suspension to match the added hp...but nothing crazy.
I opted to skip carbs and probably left about 25 hp on the table (as i wanted the reliability and economy of CIS...and wanted the car to ultimately look and feel like it was factory, but a bit more reliable and more horsepower/torque). I could have done a used 3.6 for about the same money.
If I were building another, I would do exactly the same (for a street car). For what it is worth, it is much faster and more drivable than my 3.2/G50 carrera up to abut 85 mph (due to gearing) Lots of torque and rev happy. You do have to shift a lot (due to the 7:31)...but I like that.
Geronimo 09-01-2018 07:57 AM
I would love to drive a 7:31 car, I know in the past changing the gearing can make a huge difference in the joy of driving dept.
