return tube problem
trying to install return tubes on 71 911
the outer o-rings will not slide into case or heads without deforming and coming out of slot on the end of the tube. have the green o-rings do i need the red ones?
gary burch 71 911 |
you have to use either a Bosh grease ot Sachs grease on the o rings..also green is the correct material it is called Viton...no wd40 or anything similar never.
ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
I replaced mine a few weeks ago, I used a little smear of Liqui-Moly lithium grease on the o-rings, they slid right in with no issues. So far no leaks.
