Guest
Posts: n/a
WEBER CARB BALANCING
Is there any trick in balancing the 40IDT carbs? I get equal flow at idle ok, but at part throttle there is some difference (about 2400 RPM). I believe this is responsible for the back firing in the exhaust and popping in the carbs at low speeds. There are only two shafts on each carb so it might require bending one of the shafts (not something I want to try). Any suggestions? Thanks
Bryan Wilson SMDT45A@Prodigy.com |
Guest
Posts: n/a
I've thought about the problem again and now believe the mixture is wrong because of worn throttle valve shafts. Is there an easy fix or is the refitting of the oversize (8.5mm) shafts necessary? Who can supply the shafts?
Bryan Wilson |
ASE Master Tech - 35 yrs
those carbs run on the idle circuit all the way to 3000 rpm
p.s. - backfiring & popping can a myriad of causes - one of which is crudded idle jets with resultant incorrect "tuning" of the throttle opening to compensate just google "weber carbs backfiring & popping" get a good Weber book - there are a couple OR just send your webers to Mike Pierce & get done right https://www.piercemanifolds.com/Default.asp he's a good guy
"... I am German, and if it has no logic it's meaningless." 914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
This post was from 1998!
Aaron. F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/ |
Under the radar
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() And yet the admin still won't display the original post date in the Thread Starter column.
Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage Last edited by Trackrash; 09-03-2018 at 11:27 AM.. |
hey, bryan has been waiting a looooong time for a reply, hope he gets it fixed now
they should lock threads after a certain time. only OP can post/unlock
