-   -   Revisiting an issue (http://forums.pelicanparts.com/porsche-911-technical-forum/1006856-revisiting-issue.html)
LIRS6 09-04-2018 10:43 AM
Revisiting an issue
Issue: At cold start-up, engine will idle at only about 1000 RPM's - may wander higher momentarily, but basically at 1000. As engine warms up, when engaging clutch when say coming to a stop, RPM's will drop to about 250-300 - then recovers to about 850 rpm. Once engine is warm, all is good - RPM's stay at about 900, with no near-stall issues.
Warm start - no issues.
Here's a video of typical initial cold start-up:
https://youtu.be/3QSOrRXknik
The car :
'79 SC (USA)
Original 3.0 with WUR ending 045
Temp : 74 degf
WUR ohms : 26.3
Test results :
FP only - engine not running
System pressure: 4.9 bar
Cold pressure : 2.1 bar
WUR Power connected
30 secs : 2.2 bar / 31.9 psi
60 secs : 2.45 bar / 35.5 psi
90 secs : 2.7 bar / 39.2 psi
120 secs : 2.8 bar / 40.6 psi
150 secs : 2.95 bar / 42.9 psi
180 secs : 3.03 bar / 43.9 psi
210 secs : 3.1 bar / 44.97 psi
240 secs : 3.1 bar / 44.97 psi
270 secs : 3.13 bar / 45.5 psi
300 secs : 3.18 bar / 46.12 psi
Residual pressure :
1 min : 2.3 bar
5 mins: 1.8 bar
15 mins : 1.55 bar
30 mins : 1.4 bar
60 mins : 1.2 bar
- WUR holds vacuum - confirmed
- Vacuum at line going into the WUR - confirmed
So the cold start idle should initially be at around 1800 RPM, right? And then back down to normal idle as the engine warms up.
What are the components that control that? - WUR / AAV / AAR ?
Where do I go from here?
Thanks,
Jason
T77911S 09-04-2018 11:56 AM
the AAV is ONLY used when cranking. it is like putting your foot on the gas. once the engine starts, vacuum closes it and its job is done,
the AAR is only used when COLD cranking and RUNNING. it is open when cold and slowly closes after a few minutes of running. it is heated by the same power that heats the WUR. once closed its job is done.
the WUR has several functions. it lowers the CP to richen the mixture when cold for starting AND cold running. as you can it slowly raises the CP as the engine warms to lean out the mixture.
its other function is acceleration and WOT. the vacuum control is used here to control this function. it drops the CP about .8bar to richen the mixture.
you could say there is any function related to the vacuum control.
if you still have the thermo time valve (TTV) it blocks the vac to the WUR when cold for added enrichment of the mixture for cold starting and running. this in only active for about 20 seconds.
you don't really set the cold idle. some will take the AAR apart and "adjust" it. I don't like this as I think it is covering up another issue.
the proper way to go about setting up CIS is to;
do a tune up. plugs, cap and rotor
set timing.
adjust idle, warm
verify no air leaks
check CP's
adjust mixture
adjust idle
when the engine drops down in RPM like yours is doing that is a sign of being too rich.
if it ws running fine and started doing this you need to figure out why it is now rich, if that is the case
LIRS6 09-04-2018 01:33 PM
Top end re-build last summer including plugs/cap/rotor
No air leaks
Idle adjusted warm
Cold Pressure is where it should be
Is there no smoking gun when start-up idle fails to achieve the normal ~1800 RPM?
SkiVT 09-04-2018 01:38 PM
Have you tried starting the car with your pressure gauges attached and video recording the pressures? Why? If the TTV is working correctly, your pressure for the first 20 seconds or so should stay low, or near the CCP without vacuum applied. As stated above, this keeps the mixture rich as things warm up. Once the TTV opens (at around 20 seconds) and lets vacuum take over, the pressure readings should match the readings w/vacuum applied that you took over the 3 minute window. You have confirmed vacuum happens but the timing of when is also important. For example, if the system expects to have 2.1 CCP and for some reason you have immediate vacuum, which typically raises pressure by .6, the system will be working with 2.7 pressure instead of 2.1 which I think would mean it's lean too early. Your video shows rpm recovery suspiciously around the time the TTV should be letting vacuum arrive. I know you tried correctly connecting the vacuum lines and didn't like the results before. My opinion is that doesn't mean it's not pointing out you have another problem.
SkiVT 09-04-2018 02:09 PM
It should look like thus video
https://m.youtube.com/watch?v=x3HXhqlwFMM#
LIRS6 09-04-2018 02:17 PM
Thx SkiVT, will try that one evening this week and report back.
SkiVT 09-04-2018 02:47 PM
My working theory on your situation given what you have ruled out: you are gong to see an immediate starting pressure of 2.7 instead of 2.1 Only way the car runs as well as it does at that pressure is someone enriched the mixture so it started better, I think. This then causes you to be richer across the warm up, etc. As T77911S states, if the RPM stumbles at the stop sign are from rich condition this could be why. The video will confirm the 2.7 vs 2.1 starting pressures. Rich vs lean you can then confirm by pulling down and pushing up the sensor plate during that first 30 - 40 seconds at startup when it currently stumbles below 900rpm. If pulling down slightly improves the idle, then you know it's too rich. If pushing up a little helps, you are currently too lean and I am incorrect. If it is too rich, you need to do two things: 1) vacuum line from WUR to TTV has to be plugged into the outer plug with center plug going to the vacuum source. 2) lean out the AFR a bit (best to have a CO meter for this). My opinion is your goal should be to keep the startup idle above 950 through warmup. Whether it idles at exactly 1400, 1600, or 1800 as it warms up is less critical.
T77911S 09-05-2018 04:02 AM
No air leaks
Idle adjusted warm
smoking gun would be mixture setting. but its not always a good idea to jump in and adjust it. you could be covering up another issue, especially if it ran correctly after the build and then started doing this or it has done it from the rebuild.
if mixture was never set, personally I would adjust it leaner to see if it fixes it, but then I can get it back to where it was if that is not the issue.
if it ran fine after the rebuild I would check fuse 18, then adjust mixture and try to figure out what made the mixture change to the point that I had to adjust it.
I would also check intake bolts as they can come lose after a rebuild.
you could get a gas analyzer and verify AFR setting.
if you have the TTV I would also verify how long it takes to open when cold
boyt911sc 09-05-2018 05:02 AM
Control fuel pressures........
Jason,
What are your control fuel pressures at:
a). Initial CCP with and without vacuum?
b). WCP with and without vacuum after 5 mins.?
No need to run the engine and use a hand held vac pump @ 15~16 inch Hg. Your WCP without vacuum is slightly off spec. Like to see the WCP with vacuum applied looks like. Thanks.
Tony
LIRS6 09-05-2018 06:21 AM
Never ran correctly at start-up IMO - idle was always low. Probably should have addressed with engine re-builder at the time, but near-stall was not an issue initially, and frankly I was anxious to drive the car after 8 mos in shop!
Re-builder initially had issues with idle, was making a lot of adjustments, then found vac leak (air box - was replaced). Unsure of how it was ultimately set up.
Will do
you could get a gas analyzer and verify AFR setting. Noted
if you have the TTV I would also verify how long it takes to open when cold I'll check
Comment : This may sound dumb but exhaust certainly smells rich, although cat was deleted so it could be that.
I will check starting pressure this evening as suggested by SkiVT, and as well the suggestions from Tony.
Thanks to all,
Jason
LIRS6 09-05-2018 05:02 PM
Grab your popcorn - SkiVT; you hit it right, just off by .75 Bar or so.
I haven't done any further testing, thought I'd await some feedback to this video :
Cold start up pressure;
https://youtu.be/Zx9Kd_0VMZs
Thanks,
Jason
pmax 09-05-2018 05:31 PM
Thanks,
Jason
Record the ambient temperature when you do this test.
Also, given this is a revisit as you say, it will be helpful to summarize what was already tried and done earlier.
SkiVT 09-05-2018 05:40 PM
Can you confirm for us how the vacuum lines are connected from wur to TTV? I think your July thread confirmed the wur pressures, without the engine running, were is spec both with and without vacuum applied. If the lines are not connected correctly, vacuum isnt being held off thus the too high CCP at startup. It seems the solution is correctly routing the vacuum lines so vacuum is held off and CCP at startup is lower/correct. Then tuning the afr so the engine is happy. I too am interested to see what the actual solution is.
LIRS6 09-05-2018 06:29 PM
82F
Post #1 was a summary .
Jason
pmax 09-05-2018 10:51 PM
I agree with SkiVT's observation that you are leaning out too early in general and randomly in your first video.
I would test the Thermo-valve whether it is operating consistently, closed and opening etc as the heating element is plugged in. Eliminate that little CIS elf as a source of the flakiness and go from there. Looks like that part is still available new for less than $100, reasonable by Porsche tax standards ! Your WCP is also a tad high ... that would be next thing to look at pointing to the WUR.
Good luck !
LIRS6 09-06-2018 09:38 AM
How do I go about testing it and what should I expect it to do if it is working properly?
Jason
SkiVT 09-06-2018 10:04 AM
Pull the TTV and cool it down in fridge or freezer, just needs to be 60 instead of 90. Use your vacuum pump to test each port. The outer port doesn't hold vacuum, the center port does. Assuming the center port holds vacuum, you then warm the TTV up and it should stop holding vacuum at some point. Warming it using the electricals on the TTV is best as it mimics what happens while installed.
Alternatively, plug the vacuum hoses in the way the picture from your July thread shows, start the engine with your pressure gauge installed, and watch for the CCP to stay low at your 2.1 for 30 or so seconds, and then watch it jump like in my video when the TTV vacuum opens from heating. I can't recall if you said your engine would actually run with the vacuum hoses connected as in the diagram.
Additional testing details in this link:
http://forums.pelicanparts.com/porsche-911-technical-forum/775313-ttv-test-results.html
LIRS6 09-06-2018 10:48 AM
When I had previously reversed the hoses (to what the diagram showed), the engine would start but lose revs quickly and die. Time permitting I'll try to address your suggestions tonight.
Many thanks
Jason
pmax 09-06-2018 02:55 PM
^^^Sounds like a plan. Keep us posted.
It would be nice if someone tested one of the new TTV's to be certain of the correct behavior.
SkiVT 09-06-2018 04:04 PM
An FYI: the video I posted early in this thread has a TTV I bought from our host earlier this summer. I also tested that TTV off the car just to confirm which port holds vacuum. I did not test extensivily for opening time at various tempeatures, etc. So not perfect information but the open time around 25 seconds in the video is very easy to see and it was approx 65 degrees ambient out at that time.
LIRS6 09-06-2018 07:34 PM
I didn't have time to swap hose positions on TTV, nor remove/test it, but I did remove the heater blower to allow greater visual inspection of the plumbing.
If it's supposed to look like this...
http://forums.pelicanparts.com/uploa...1536285182.jpg
... it doesn't.
As previously discussed, the vacuum hose from my WUR goes to the middle port of the TTV. The hose from the side port of the TTV then goes to a "T" fitted on to the Vacuum Limiter. The hose on the other side of the "T" goes into the throttle body(?) on the back side (not the front side as in the schematic).
http://forums.pelicanparts.com/uploa...1536286696.jpg
Here's the port (circled) that the split from the TTV is supposed to go into per schematic
http://forums.pelicanparts.com/uploa...1536287367.jpg
Here's a vid:
https://youtu.be/R1d5OJ-_nek
Does anyone have photos of a dropped '79 USA engine showing CIS intact?
Thanks,
Jason
pmax 09-06-2018 09:09 PM
Don't follow that parts diagram. Jim William's excellent CIS primer has the correct diagram of the vacuum connection.
The hose goes to the front (of the car) side of the TB and that's what your video shows which is correct.
Stay the course with either of the alternatives SkiVT has detailed earlier to isolate the TTV as the possible culprit here.
pmax 09-06-2018 09:36 PM
Cool, your video might be the first in this forum showing how the TTV is supposed to operated from the factory. Those other tests in your link earlier were all done with decades old parts.
SkiVT 09-07-2018 03:34 AM
My line from the decel valve to TB is as in your video. You could just attach your vacuum pump to the TTV ports while in the car. Other threads have vacuum holding until the temp hits high 80's so it may be cool enough in your garage. My belief is your TTV holds vacuum as you said when the hoses are correctly connected, the startup idle got worse. If it wasnt holding vacuum, idle would be the same as the 2.7 ccp pressure you observed because vacuum is happening immedietly. My guess again is the afr has been tuned for startup at 2.7 CCP. When you correct the hoses and vacuum is held off, your CCP is 2.1 which will then drop/richen your afr, which ends up being too rich to make happy idle.
T77911S 09-07-2018 04:03 AM
the vacuum port from the TTV (WUR) goes to a port that is BELOW the throttle plate, IE manifold vacuum.
you vac on the WUR all the time except WOT. it will lose vac when you accelerate momentarily. helps with acceleration.
LIRS6 09-07-2018 09:45 AM
I have the primer, but the only diagram I saw was in essence the same as the one that I posted. *Update : found it
Thanks, I found a pic of my engine out, prior to the top end re-build, which shows the original placement of hosing.
http://forums.pelicanparts.com/uploa...1536338353.JPG
Will do so, have time this w/end.
Thanks,
Jason
LIRS6 09-07-2018 10:00 AM
... it looks a bit different now ...
http://forums.pelicanparts.com/uploa...1536339442.JPG
http://forums.pelicanparts.com/uploa...1536339543.jpg
LIRS6 09-08-2018 06:55 AM
I removed the TTV, and first tested it with a vac pump - the middle port held vacuum when cool. I then attached two wires to the TTV, and ran them to my battery - to mimic the electricals, as you suggested. After about 13-14 seconds, the TTV opened up, and vacuum was lost at the middle port.
So my understanding is that this supports that the TTV is working as it should. I expect from prior testing that once I reverse the lines to/from the WUR and Decel Valve, the engine will fail to maintain idle. As I further understand it, this then suggests that the mixture is too rich .... so the next step would be to adjust the mixture to lean it out?
A pic of what I used, should anyone have interest :
http://forums.pelicanparts.com/uploa...1536414777.jpg
Thanks,
Jason
pmax 09-08-2018 09:42 AM
Before doing that, measure the fuel pressures engine running with the TTV correctly connected. If the engine dies, pull down (assuming it's too rich) the sensor plate slightly.
LIRS6 09-08-2018 12:03 PM
Thanks pmax.
Reversed the hoses to the TTV, so that the Decel Valve hose went into the middle port, and the WUR hose into the outside port.
Ambient temp: 73 F
Hooked up pressure gauge, vacated air from the gauge hoses, and fired her up. Frankly I didn't expect it to hold idle, as previously it hadn't, but it did this time.
As you will see in the video below, initial pressure at start up was about 3.0 Bar. After about 15 seconds (TTV opens up?) the pressure starts to increase, although not rapidly as SkiVT's had in his video. Ultimately it reaches about 3.8 Bar.
At about 48 secs, I start to play with the sensor plate; pulling down slightly loses idle. pushing up slightly does the same, as you will hear. I tried it a few times, as you will see.
At about the 4:41 mark, you will see me remove the vac hose from the WUR - FP drops about .3 Bar. Then I reconnect it. Back it goes to 3.8 Bar.
What you don't see is that the idle has dropped to about 800 RPM by the end of the vid. So subsequently I adjusted to about 950.
https://youtu.be/PCa6j_ABuzo
Warm start-up was smooth.
Thoughts?
Thanks, Jason
LIRS6 09-08-2018 12:46 PM
Originally Posted by boyt911sc (Post 10168298)
Jason,
a). Initial CCP with and without vacuum?3.0 Bar @ 73F with vacuum - haven't done it w/o vacuum
b). WCP with and without vacuum after 5 mins.? 3.8 Bar / 3.5 Bar
(Am I correct in believing that if I disconnect the vac hose to the WUR, that I am testing FP "without vacuum"?)
Jason
pmax 09-08-2018 05:27 PM
I think the TTV is open, sending vacuum to the WUR, throughout your test today. The gradual rise in pressure is due to the WUR heating up, not the TTV opening up. Looks like it's running fine this time with the TTV correctly connected. Unfortunately, that doesn't help when the previous stall problem can't be reproduced.
I would check the AAR next. When the engine's cold, disconnect the hose (part metal on the "outside") to the AAR, use a mirror and see if it's partly open.
http://forums.pelicanparts.com/uploa...1536461147.jpg
SkiVT 09-09-2018 04:21 AM
Something seems amiss. Your pressures in your first post have 2.1ccp then increasing over time as they should. Now the video at startup has ccp at 3.0 with same ambient temp? Is this a cold start video?
LIRS6 09-09-2018 05:05 AM
Checked - it’s open (btw, I just stuck my phone there and snapped a pic):
http://forums.pelicanparts.com/uploa...1536494652.jpg
LIRS6 09-09-2018 05:13 AM
2.1 was initial cold pressure engine not running/WUR power disconnected. 3.0 was cold start up (engine running). Maybe my terminology is inaccurate?)
SkiVT 09-09-2018 11:05 AM
When the TTV is working, your ccp should hold at 2 for 15 to 25 seconds, then rise like it did when you plugged the electical to the wur in your no engine running tests. The no engine running test simulates power coming to the wur when you start the engine. Jumping immediately to 3.0 seems strange, particulalry if vacuum is held off by TTV.
pmax 09-09-2018 11:14 AM
OK, so we are getting some extra air on startup.
Here's my next suggestion.
Run the same fuel pressure tests under the same conditions as in your original post, no engine running to verify the FP is 2.1 as before but this time, also monitor the AAR opening as well during the test. The AAR should close completely after a few minutes.
However, as SkiVT says above, the TTV is supposed to be open during startup in your latest video. I would defer to that given there is no one else who has tested a new TTV.
LIRS6 09-09-2018 03:36 PM
Originally Posted by LIRS6 (Post 10167351)
The car :
'79 SC (USA)
Red font are readings taken today. TTV hoses reversed to normal position (hose from Decel Valve in middle, WUR hose on side)
Temp : 74 deg F 66 deg F
Test results :
System pressure: 4.9 bar. 4.8 Bar
Cold pressure : 2.1 bar. 2.3 Bar
WUR Power connected
30 secs : 2.2 bar / 31.9 psi. 2.55 Bar
60 secs : 2.45 bar / 35.5 psi. . 2.6 Bar
90 secs : 2.7 bar / 39.2 psi. 2.9 Bar
120 secs : 2.8 bar / 40.6 psi. 3.0 Bar
150 secs : 2.95 bar / 42.9 psi. 3.2 Bar
180 secs : 3.03 bar / 43.9 psi. 3.3 Bar
210 secs : 3.1 bar / 44.97 psi. 3.35
240 secs : 3.1 bar / 44.97 psi. 3.4 Bar
270 secs : 3.13 bar / 45.5 psi. 3.4 Bar
I checked the AAR - did I do this correctly?; I had the ignition at "on", engine not running. Left it on for a good 8 mins or so. AAR did not close.
Thanks,
Jason
SkiVT 09-09-2018 03:52 PM
AAR: I believe the AAR (and WUR and TTV) only gets power with the key in the starting position and when engine running. Just turning the key to run does not energize those parts. I think if you energize it like you did with the TTV, that should be a better test. I did that after taking it out of the car. Put the AAR in the freezer to see it fully open (or not) and then apply power to watch it close.
pmax 09-09-2018 04:25 PM
Thanks,
Jason
The AAR shares the same 12V with the WUR, so if the WUR is heating up with the FP relay bypassed as described and the AAR is not closing, the latter's probably busted. Try squirting some WD40 and see if it frees up, can't hurt.
The WUR also appears inconsistent given the lower temp should result in a lower CCP not higher as you reported.
