How to hide a radar detector?
Not that I would ever consider exceeding the speed limit
, but I'm thinking about getting a Valentine One. They are illegal in VA, so I would need have it as well-hidden as possible, if I were to ever "theoretically" consider using it in VA. What are the chances of my having this well-concealed and it still working to maximum effect? Anyone have photos of how to best install these in a 911 and keep them hidden? Sorry for the dumb question. Thanks.
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
No pic Richard, but a 356 friend of mine who also lives in that state says a hollowed out sunvisor hides his V-1 just fine. Be sure to have a quick shut off switch tho....wouldn't be cool for the officer to hear the beeping & see the lights flashing should you get pulled over. I call a wrecked-em yard, see if you can buy a sunvisor with foam already bad for cheap...play with it a bit...
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Officer: "Son is that a thick sunvisor or are you just glad to see me?"
Put it in something normally found on dashes: kleenex box with strategic holes, doughnut box (no wait the cops might look in there), make "cast" that looks like a bunch of papers piled up in the front of the dash and hide it in there. Inside a "hulu girl" doll? Make a special right hand mirror and hide it in there. Wear a hat and hide it in the top. The possibilities are endless.
Jim
Not to be a pain, but I have found if you run at any speed at all, you basically almost outrun the capabilities of even the good detectors. Plus the false alarms and such make detectors more hassle than they are worth to me. If I am going for a spirited run, I always go through the stretch first and then backtrack to make sure it is both safe and radar free. Just my 2 cents worth.
Alan Poh '77 Carrera 3.0 |
i got busted for a detector (but not speeding) in va in 79 and i have not used a detector since.
72 911t grey/black mine 74 914 2.0 black/ tan hers 02 g500 black/black womanproof 01 f250 psd dirty the mule 60 correct craft starflite cool 69 correct craft torino hauls butt 72 correct craft ski nautique fun 66 vw 1500s will finish someday |
Also, unless you put it in a good Faraday cage (which makes it useless) a good radar detector detector is going to find it. Cheers, Jim
I'd say not true on many counts. The V1 has proved invaluable in my friend's jaunts, including over 100 mph. In addition, the predator, or whatever the detector detector is called, couldn't find a V1 from more than 10 feet away.
An idea that I played around with was mounting the V1 in the high center-mount brake light, with appropriate wiring to a concealed display. If you don't want to wire it that much, I'd go with the sunvisor route. I'd shy away from anything on the dash, which can be a ticket for obstructed view, and then might lead to the detector being found. Remember though: "Speed Kills." Jared
89 Carrera 3.4 "There is a right way to go around a corner - it's called the line." -- PCA DE speaker bryteside.com - good things happen. |
My VA friend reported that his system worked great, gave lots of warning. He said the VA cops, because detectors are illegal there, tend to use the older equipment that is most easily detected, giving him tons of warning time.
I said a "good" radar detector detector. I had a collegue get busted for speeding by a state policeman out on the JJanno by Vaugh, NM using the telephone poles and stopwatch method. His V1 wasn't a whole lot of help.
Jim
Buy them, sell them
Richard,
My '76 has a tinted 2.5" band at the top of the screen, and I mount the detector, high up against the roof at the top of the screen, beside the rear-view mirror. I route the power cable along the window seal and have it hard wired to the ignition, via a little switch for "emergencies". From the outside, even standing next to the car, it's invisible. From behind/beside, you can't see it because the roofline decends lower than you'd think, so you can't even see the lights. I'll take a photo tonight and post it for you. It's nice and high and seems to have paid for itself many, many times over. I have literally stopped at the lights right next to a Police car and gotten away with it. Of course, it's pucker time, every time!
1931 Oakland Eight Special Saloon 1985 BMW E28 525e (Euro 528e) 1989 911 Carrera Sport 3.2 G50 Cabriolet |
flush mount it into the mirror, it's the stealthest I've ever seen the V1 done and there's no way unless the driver gets in the driver's seat and looks at the mirror that he'd notice it.
later, amir
Amir '83 911SC |
I live in N VA and have a Valentine and it works well. I use it in my RSA when cruising or p/u truck when towing. I mount it on the windshield at the dash. When it goes off I look around to see if there's an obvious police car around and the arrows are somewhat of a help. The Valentine gives plenty of warning except for laser and you're dead with that anyway.
If the police are in front I'll pull it down off the dash and drop it in the passenger seat or somewhere. I only use the detector when I'm on the highway so that works for me. My biggest concern is radar coming from the rear at night when the detector goes off and starts flashing lights. Had one detector confiscated because of that and yes, I did get it back. I paid the fine, waited till after the court date and called the police property divison. They told me the cop had not released the detector, left several messages for the cop, phone call never returned. Call the police chief and got a return call from the cop the same day, retreived the detector the next day. ![]() Is this land great or what?
Original Owner
Maybe one of the "screen room" engineers on this site could design a jammer relay triggered by the detector. Use some old magnetron and a waveguide mounted under the front of the car near the tow hook. Not sure about getting a HV source but if you could the police would never know what happened.
Of course as they look at wavy white lines you go by at 95! So they might run you down anyway!
tsuter 78 911SC Turbo Targa Thaaaats Right!! |
some great advice has been offered.. Valentine will custom make anything you want.. you should have rear detection also.. Calif HP has been using it.. never be the point man.. follow bear bait.. the higher it's mounted the better.. if big rigs are doing the exact limit there's a reason.. you may be able to pick up laser scatter if you're directly behind the bait.. stay back 1/8-1/4 mile.. SUVs in the left lane at limit + are the best bait, IMO.. If you feel you have to be in front of the pack, forget about any detector.. there's always someone with an ego problem when they see a 911 on the road, wait it out.. and for big audio crusing you can wire the V-1 into a mono amp/speaker, that's another story.. and to avoid false triggers you can customize the V-1 settings.. I like the idea of a custom rear view mirror, with most of V-1 hidden under dash, and a custom LED bar and arrow in sight, w/ an emergency off sw close by... nothing is 100%, but give it your best shot.. it makes driving more relaxed
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
911 + 129 = JOB
I currently have a K40 in mine. The brains are mounted on the glove box roof which houses the lights and city hwy settings. On either side of my Tach are two red lights very tiny (just bigger than a ballpoint pen and when not blinking red are virtually unnoticeable. I relocated the speaker (and upgraded to a louder sounding one) so that it is below the oil and gas gauges. Just a black nickle sized piece of plastic. Non-Porsche wouldnt notice. Next to the ignition is a toggle switch that turns the system on and off. Lights up green when on, no lights when off. Again, if you do not know the car, you do not notice it. The sensor is mounted in the front bumper. I did not have it installed or I would have mounted it behind the black grill on the hood.
The system works great and I am going to add the laser option which mounts as a license plate frame on the front license plate (black plate with Porsche crest and the frame is black). I would love to get a V1 but they do not offer a remote installation. Something about it being less effective. I cannot see why its any less effective if they can still mount the sensor and all the hardware under dash or in the glove box etc. I thought I read about a company that would redo your rear view mirror and the back side of the mirror was the sensor for the V-1 and the readout appeared on the mirror glass itself. My guess is that I found the link to that from Pelican or Rennlist. Just my .02. Look at my links one has some pictures of it.
1989 911 Carrera Coupe 3.2 2012 BMW 135i M Sport "It is not how much power you have, it is how much you have left to spare!" |
Super Moderator
Here's my Valentine setup (from a much earlier post). You can't see it from outside the car, or even casually leaning in.
Also see Questions on Mounting the Valentine 1?
Mine is mounted sortof like Chris's. It is hard to see from the outside unless the sunroof is open.
Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno, |
I mount mine like Chris' too, just above the mirror with a long tag line running around the window trim. It's works great there. Be sure your detector has the "shadow" technology - so the nice police officers don't detect your detector.
Question, I once had a bad experience hard wiring my cell phone charger that pluged into the cig lighter. Turned out there was more than just the 12V in that plug? I've got the Vector detector that plugs into the cig lighter, Can you hard wire this and get rid of that plug into the cig lighter without hurting the detector? It would be nice not having to bring that wire out to plug into the cig lighter. Anyone know for sure? Amir: Can you get photos of that detector let into the mirror, that sounded pretty cool to me.
Rob McKibbon, Shuswap Boy <>< To steal ideas from one person is plagiarism, to steal ideas from many is research. Currently researching ideas for my '74 911 Cabriolet |
My last radar detector experience in VA: On my way back to Va Tech on 460 in Appomatox... radar detector on and well hidden, me doing the speed limit (no, really)... blue lights... Me: "Is there a problem, officer? I wasn't speeding" Him: "I don't know know how fast you were going. Let me see your radar detector. Here's your summons. Have a nice day." He never hit me with radar, so I never know he was there (and didn't have a chance to turn off the detector) until the lights went on.
Chris M 1985 911 Carrera w/ 3.6 |
