What ATE calipers are these for?
Cant figure out what these calipers belong to. Took them off the rear of my 914. Anyone know? 34mm piston.
cycling has-been
What is the bolt spacing? They look like they will mate to solid rotors only.
Where is the e-brake adjuster on these? Porsche made the solid-rotor version for the fronts on the 914 and 912E with both 3.5" and 3" hole spacing; so if there is no provision for the e-brake adjustment, they are probably fronts. (For the definitive answer, wait for Bill Verberg to chime in.) Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
Stock rear caliper for a 911 with vented rotors. could be front from an non S as well.
Aaron. F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/ |
It's not a front M, the bleed would be in the middle
best guess is a '69 rear narrow M these were used on 18mm non vented rotors and came w/ either 35mm pistons or 38 mm pistons, depending on what the fronts used.
There are spacers between the caliper halves. IIRC,The solid rotor variants did not have them. Examples below of solid rotor units.
AFAK only the early narrow(18mm rotor) calipers used the 35s, but then I know very little about 914s
