-   -   Engine question (http://forums.pelicanparts.com/porsche-911-technical-forum/1007205-engine-question.html)
yev 09-08-2018 03:39 AM
Engine question
Guys
Can anyone tell me what engine is this?
Here is the engine number 911776
djpateman 09-08-2018 06:18 AM
1967 type 901/06
below the 901/06 there should be a build #, probably close to 8600; what is that # please.
In 1967 there were two engine types. This is the normal 911 engine for the year, the other was the 911S type 901/02.
yev 09-08-2018 07:21 AM
http://forums.pelicanparts.com/uploa...1536416437.jpg
thanks
but thats all the digits? see pic
yev 09-08-2018 07:42 AM
so would it be correct engine for 1968 911 coupe? VIN 11835xxx
yev 11-18-2018 12:21 PM
so why is every other engine I see on 67/68 models starts with 3 number? not 911?
ossiblue 11-18-2018 01:17 PM
That engine number would not be correct for a 1968 model year 911.
For the 1968 model year, the engine numbers became 7 digits, with the first digit determining the model of chassis (really, the engine for the particular model--2=L, 3=T, 4=S ) it would be in, so the first digit could be a 2, 3, or 4--a 1 designated a 912 engine. In 1969 model year, the numbering changed to the 6 digits with a "6" always the beginning number, representing the number of cylinders.
BTW, the 901/06 type number mentioned by Djpateman will be found on the flat, horizontal surface of the case, just to the right of where you found the engine number which is on a vertical piece.
HarryD 11-18-2018 01:30 PM
There should be an engine number stamped near the serial number you show. This picture shows the locations:
http://forums.pelicanparts.com/uploa...1492546696.jpg
yev 11-24-2018 03:37 AM
Originally Posted by djpateman (Post 10172969)
1967 type 901/06
It is 901/06 and below 8644
