yev yev is offline
Engine question
Guys
Can anyone tell me what engine is this?
Here is the engine number 911776
Old 09-08-2018, 03:39 AM
djpateman's Avatar
1967 type 901/06
below the 901/06 there should be a build #, probably close to 8600; what is that # please.
In 1967 there were two engine types. This is the normal 911 engine for the year, the other was the 911S type 901/02.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 09-08-2018, 06:18 AM
yev yev is offline
thanks
but thats all the digits? see pic
Old 09-08-2018, 07:21 AM
yev yev is offline
so would it be correct engine for 1968 911 coupe? VIN 11835xxx
Old 09-08-2018, 07:42 AM
yev yev is offline
so why is every other engine I see on 67/68 models starts with 3 number? not 911?
Old 11-18-2018, 12:21 PM
That engine number would not be correct for a 1968 model year 911.
For the 1968 model year, the engine numbers became 7 digits, with the first digit determining the model of chassis (really, the engine for the particular model--2=L, 3=T, 4=S ) it would be in, so the first digit could be a 2, 3, or 4--a 1 designated a 912 engine. In 1969 model year, the numbering changed to the 6 digits with a "6" always the beginning number, representing the number of cylinders.
BTW, the 901/06 type number mentioned by Djpateman will be found on the flat, horizontal surface of the case, just to the right of where you found the engine number which is on a vertical piece.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 11-18-2018, 01:17 PM
HarryD's Avatar
There should be an engine number stamped near the serial number you show. This picture shows the locations:
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 11-18-2018, 01:30 PM
yev yev is offline
Originally Posted by djpateman View Post
1967 type 901/06
It is 901/06 and below 8644
Old 11-24-2018, 03:37 AM
