-   -   Shifter rotation orientation? (http://forums.pelicanparts.com/porsche-911-technical-forum/1007221-shifter-rotation-orientation.html)
Jameel 09-08-2018 07:38 AM
Been playing around with getting my shifter into it's best position. Turned a shifter extension ala John Walker (I'm a tallish guy) but now it's digging into the side of my fat leg more since it's higher. Also have sport seats, so I'm lower in my body position. I noticed that the upper half of the shifter (the dog leg) is pointing towards the driver a bit, not straight back. I noticed this in my brother's SC as well. I know these tend to come loose down below, so I'm wondering if someone got the rotation wrong during a repair. Anyone know what factory setup is? And if I want to rotate mine away from my fat thigh, I assume I have to rebraze/weld down below?http://forums.pelicanparts.com/uploa...1536418130.jpg
http://forums.pelicanparts.com/uploa...1536418306.jpg
wareaglescott 09-08-2018 10:51 AM
Cant answer your question about adjusting it but I did go look at my '79 SC and when mine comes straight back it is in alignment with the parking brake handle not slanted off to drivers side like yours.
Jameel 09-08-2018 11:20 AM
Thanks for looking. Hopefully we'll get some others to chime in.
7783911 09-08-2018 01:17 PM
ever consider turning a few extra extensions and selling?
wareaglescott 09-08-2018 01:38 PM
If you need something custom made and turned I have used this guy. Very nice quality work and a good guy.
https://www.lathewerks.com/?SID=tv8bjsa4ap423s6krd145cq8sv
uwanna 09-08-2018 01:52 PM
Sherwood (911pcars) from Seine Shifters also sells shift stick extenders
that work great, see here:
http://forums.pelicanparts.com/porsche-911-technical-forum/623159-yet-another-shifter-thing.html
john walker's workshop 09-08-2018 01:59 PM
Heat the shaft with a torch below the boot and bend it over to where it clears your leg and the seats
Jameel 09-11-2018 03:24 PM
As always, thanks for the great advice John. I heated it up right above the dog leg and eased it over until it was pointing straight back. Put my extender back, went for a drive and.....aaaaaaaahhhhhh!! No more leg interference at all. And the shift knob falls above my leg now instead of right in the middle of the thigh. I rather enjoy the reduced effort as a bonus. Shifts are a little longer, but easier too. One of the best mods I've done to the overall comfort and ergonomics of the car. 2000 miles to Rennsport here I come!
http://forums.pelicanparts.com/uploa...1536704644.jpg
911pcars 09-11-2018 06:30 PM
It all depends. The shift lever is a two-piece lever joined by an epoxy-like glue.
The factory alignment is straight back along the fore-aft axis of the car. At some point in time, the top half separated and was re-attached to the lower part.
- If weld-repaired, your reheating and bending to realign should be good.
- If re-epoxied, your reheating could have compromised the bond. Depends on the amount of heat and where localized.
Inspect the lever joint for signs of a weld bead. If visible, you're good to go.
Sherwood
tmadden2 09-11-2018 07:10 PM
I’m interested to hear more about how that cell phone magnet is mounted. How did you attach it to what appears to be the HVAC panel?
Jameel 09-11-2018 08:00 PM
Sherwood
Great info! I will take a look.
Jameel 09-11-2018 08:01 PM
Camera angle. It's the Rennline clock mount.
Flojo 09-12-2018 03:04 AM
hope that heating and bending it will not brittle the shaft and hope it does not break when doing a hard shift...
