964 Harness Question
When removing the harness from a 964 to run the engine, do I need to remove the group of wires that go into the passenger side of the cabin? I already got out the wires that go up to the underside of the driver seat. From what I can tell the only plug that comes from the passenger side and goes into the motor is for the cruise control. Does the wiring in the passenger side run up to the fusebox or is there a connector somewhere that can be unplugged?
Can't I just cut that side off as long as the driver side is intact?
IG @Drola964 1973 BMW 2002 1990 964 C2 2007 GT3 2014 Ram 2500 Cummins |
