-   -   Help needed to Identify engine block (http://forums.pelicanparts.com/porsche-911-technical-forum/1007626-help-needed-identify-engine-block.html)
BoxsterGT 09-12-2018 09:02 AM
I have an older 911 short block out in my barn with "628xxxxx" for the first three digits.
Is this a 911E designation?
Or is this too early for the T, E, S models?
Len
Matt Monson 09-12-2018 09:27 AM
Len,
Are you sure it's not 629? 628 should belong to a 78 SC engine. '69 used the 629 start, but earlier engines, like 1968 would have used the previous system starting with a 2,3, or 4.
What's the type number? Should be right below the serial number on the case.
BoxsterGT 09-12-2018 09:44 AM
Thanks Matt, it is type 930/04 so its a 911SC.
Forgot Porsche switched the sequence of model numbers.
So, the "2" is the model and the "8" is the year. I have a SC long block.
Will get photos and post this in the used parts for sale section.
Len
