72 911 coupe body flex
This post has been in the 'Paint and Body" forum section for over a month with lots of views but no responses....Thought I would try here.
72 911 coupe body flex I am turning my '72 911 non-sunroof coupe back into a street car. It was a DE car with a 3.6 (993) engine and 915 trans. I will reuse the engine, but will install a G50 trans. The rear quarter panels have been flared (with metal) to accommodate 16x9 Fuchs with 295s. It also has rear coil over suspension. I need to stiffen up the body. The most notable issue is body flex making the driver's door stick. I do not plan on having a roll cage or roll bar. The car has been stripped and primed, and rust repairs are starting soon. What are my options? I suspect there is already a thread in the forum, but I could not find it. Richard |
how true is the body?
I have a celette which we use to make sure the body is true before we body work the car. i am in tarpon springs florida if you are interested in any services. you can buy aftermarket gussets for the body but considering it is going back to a street car you dont really have to gusset it. for aligning the doors, the hinges and pins might need to be checked. And fitted with new rubbers during the fitment process.
WANTED: 1967 Transmission #103586 1967 Transmission #200082 1969 Engine#6195922 1969 transmission#7194313 1969 transmission#7195495 |
Metal fatigue, hidden rust or poor prior repairs. Car is almost 50 years old
Vintage Owner
Using the Celette Bench as a first step will pay big dividends in the future as you can be sure things are properly aligned before going forward and running into issues.
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
Location: behind the redwood curtain, (humboldt county) california
Garage time stitch-seam welding
His video goes through the process and his testing to quantify the benefit. Might be nice to make sure the car isn't tweaked with a Celete first.
Good luck |
look into the updated and expanded late 80s kidney bowls
