Mrdi's Avatar
Tire SO3
My search netted advice on racing so....
Suggested street tire pressure for
SO3 245x45x16 and
So3 225X55X16
Tire mounter suggested F38/R48 seems Hi.
Break in suggestions?
All Comments appreciated.
Thanks,
Mrdi
Old 03-18-2003, 08:29 AM
Super Moderator
cstreit's Avatar
I run about 34/36 street in cooler months. 32/24 hot summer. Seems good.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 03-18-2003, 08:34 AM
Pressure requirements can vary depending on WHAT 225 or 245 you have mounted. I found myself running 36/42 once to keep the rears from scrubbing away the center tread. Try to get actual S-03 info if you can, they've been out long enough now that there should be easy to find that experience on this board.
Charlie Baer
'79 Euro 911SC (Guards Red)
'83 Quattro (Mars Red)
Old 03-18-2003, 08:48 AM
Mrdi's Avatar
Just called tire rack. They say 29/36 ?
Mrdi
88 Carrera G50
Old 03-18-2003, 09:10 AM
racemor's Avatar
How does tire rack's recommendation compare to factory settings? I'm wondering because I'm using stock pressures on my '73 with 205-55 SO3, which are a very different size from the originals.
Tom
'18 Carrera T
R #368, S #692
North Carolina
Old 03-18-2003, 10:05 AM
NYSCAR's Avatar
Send a message via AIM to NYSCAR Send a message via Yahoo to NYSCAR
Hey racemor,
I was thinking about the 205/55-15 SO3's for my 73 S, how do they fit on your car? you like 'em? How do they look (smaller?)?
Brad
73 911S Coupe sold
Old 03-18-2003, 10:07 AM
Mrdi's Avatar
The 225 55 16's fit on the front of my 88 911, I've heard of others having problems but not with the 15" wheels
Mrdi
88 Carrera G50
Old 03-18-2003, 10:10 AM
Automotive Writer/DP
Randy W's Avatar
I've had mine about a year - great tire. SO3 pressure are somewhat camber dependent - if you have 1/1.5 degrees negative, 32/35 on a 2400 lb car seems to work well. Less camber seem to need higher pressures. Break-in is not absolutely necessary, but best would be two medium speed laps followed by a hot lap then store tire/wheel off car for a few days.
1972 S - Early S Registry #187
1972 T/ST - R Gruppe #51
http://randywells.com
http://randywells.com/blog
Old 03-18-2003, 10:11 AM
Mrdi's Avatar
I'm primarily
LOOking for street pressures not track
SO3's
F 245 45 16
R 225 55 16
Mrdi
88 Carrera G50
Old 03-18-2003, 10:15 AM
racemor's Avatar
Brad, I love the tires! I've tried a good number of hi-perf street tires over the years on different cars. I think these may be the best I've had. Only a Hoosier or Kumho DOT race tire seems to have more ultimate grip. Seem to be as good in the wet as in the dry based on our local wet weather Pelican mountain drives. They are a little short but I am still running nearly stock ride height and alignment. I'll fix that with new torsion bars and shocks this summer I hope.
Here is a shot, mine is the silver car at the front of the row.
Tom
'18 Carrera T
R #368, S #692
North Carolina
Old 03-18-2003, 10:46 AM
Senior Member
Superman's Avatar
The greater the difference in pressures between front and rear, the greater the car's tendency to understeer. I use pressures a bit closer. Fronts are only 2-3 lbs less than rear.
Too little pressure causes tires to flex more, heat up more and wear faster, particularly in the tire's center where heat is greatest. Higher tire pressures do not sacrifice grip, they only run cooler and firmer, and wear longer.
Mocha 1978 911SC. "Coco"
Old 03-18-2003, 10:51 AM
Mrdi's Avatar
So what numbers would you put with your comment
Superman?
F 36
R 40
Mrdi
88 Carrera G50
Old 03-18-2003, 10:57 AM
curtisaa's Avatar
Racemor
your car appears to have 6's & 7's. What tyre sizes are you running ??
Old 03-18-2003, 11:34 AM
Mrdi's Avatar
Fuch 7 225 55 16
Fuch 8 245 45 16
Mrdi
88 Carrera G50
Old 03-18-2003, 12:09 PM
racemor's Avatar
Curtis, they are 15" x 7" all around, 205/55-15 all around, rolled fenders. Only rubs in the really rough stuff pushing very hard. New alignment should help.
Tom
'18 Carrera T
R #368, S #692
North Carolina
Old 03-18-2003, 01:30 PM
NYSCAR's Avatar
Thanks for the info Tom, I think those will be the next tires on my 73 (not bad price on tirerack.com too!). BTW very nice looking E there
Brad
73 911S Coupe sold
Old 03-18-2003, 02:23 PM
curtisaa's Avatar
tight sqeeze
I am about to order thru Tire Rack 225 X 55 X 15's for the rear of my 70S. I have the deep 6's. I used to run these (225's) on my ex-73S but like you've done looks like I may have to roll the rear. We'll see..
Old 03-18-2003, 02:29 PM
Randy Webb's Avatar
If I have 6" F and 7" rear wheels on my '73, is there a size of S)-3 that will fit? For sure? Or is it just an experiment to see if they fit w/o rubbing?
Old 03-18-2003, 02:41 PM
RallyJon's Avatar
Smile
Better late than never... I just swapped the Euro T/A balloon tires out for S-03s in 205/55-15 front and 225/50-15 rear. The S-03 is a very wide tire. The fronts are actually 218mm wide on 7" wheels and the rears are 233 mm wide on 8" wheels. If they don't quite fit there are other tires in the same nominal size which are smaller.
Here are a few pics.
993 · 911 · STI · S4 · rally car
Old 03-18-2003, 06:56 PM
