clutch pedal not completely to home position
My clutch pedal does not completely go back to its "home" position. I have made a short clip to show the problem. Where should I start to look for. The clutch adjustment is spot on
Please see the clip here:
https://youtu.be/4BW9xE_hmnM
thx
Old 09-16-2018, 04:08 AM
Very common issue. A pedal cluster rebuild is in your future.
https://www.pelicanparts.com/techarticles/Mult_pedal_cluster/Mult_pedal_cluster.htm
Lots of threads in this forum on rebuilding the cluster as well.
Old 09-16-2018, 04:22 AM
Adjust the Bowden cable at the transmission. Moving the Bowden forward brings the pedal up then the engagement adjust up so there is two things happening that you need to be in the driver seat for.
Bruce
Old 09-16-2018, 05:58 AM
Bruce
Thanks fot the reply. By moving the bowden you mean where the clutch cable is attached to the transmissioncase with the two adjustment nuts?
Old 09-16-2018, 10:44 AM
Member 911 Anonymous
DRACO A5OG's Avatar
also the pivot area appears to be binding, try lubing it and Omega ring at the pivot.
+1 check all gaps (1.20 /1.00MM) and throw (25MM) are correct.
Have a help do what you did and observe below.
'85 Carrera Targa
PCA/POC
Old 09-16-2018, 11:36 AM
Yes, with the 2 15mm nuts.
It doesn’t take many turns to change drastically
Bruce
Old 09-16-2018, 03:00 PM
