-   -   damage on my case... is this an issue? (http://forums.pelicanparts.com/porsche-911-technical-forum/1007965-damage-my-case-issue.html)
Trakrat 09-16-2018 08:00 AM
I noticed that something had fallen into my recently machined case half and damaged part of the mating area and edge. (apparently someone knocked something off a shelf and it fell)
Does this need to be repaired? Is this acceptable still?
Please look at pictures and comment. Thanks!!!!
http://forums.pelicanparts.com/uploa...1537109968.jpg
Steve F 09-16-2018 09:27 AM
I would just take a flat stone and wrap it with some 600 grit sandpaper and just slowly run over the area until there is no burr left then stop, you will be fineSmileWavy
proporsche 09-16-2018 09:59 AM
A Steve said not a big deal if it is smooth and no lip do not worry too much-it is more to the inside of the case......but, i would send the picture to the machine shop who did the damage and was not careful with your engine case..
Ivan
Trakrat 09-16-2018 10:54 AM
its not a burr... but a dent. case was on the ground and something got pushed off counter top and fell onto it and caused the dent.
There are 2 dents where the mating occurs as well as a dent on the outer edge.
Trakrat 09-16-2018 10:55 AM
Ivan
it was my own fault... a hose nozzle fell off and landed on the case.
the edge is flat, just a couple of dimples/dents and the outer edge is slightly hit.
76FJ55 09-16-2018 11:04 AM
By the picture it looks to me like that was preexisting when the machine work was done. I don't se any distortion to the machining Mark's, and you say there is no high metal, which would confirm this. If that had happened after machining, that metal would have been displaced causing the adjacent metal to be high. If the mating surfaces are smooth you are good.
proporsche 09-16-2018 11:12 AM
trakrat..i c, in any case do not worry too much...............
Ivan
DRACO A5OG 09-16-2018 11:30 AM
+1, Don't worry about it. Thanks goodness you missed the Journals, then we would have a another story here. Just be mindful and keep cats away, darn hair can kill your engine. :-)
Trakrat 09-17-2018 06:42 AM
Good to know.
I did notice a small 'knick' on the edge of one of the journals. The only reason I noticed was from the light bouncing off it and made it shine more than the journal itself. My fingernail catches on it when I run it along the edge.
I don't think it should be an issue as it is really small and I should be able to file it down on the outside edge of the journal to smooth it out slightly.
Trakrat 09-17-2018 06:44 AM
Apparently it was a solid, straight hit... I found my hose nozzle has a metal grip that matches the indention that was made.
uwanna 09-17-2018 07:15 AM
Much ado about nothing,the case sealant will fill that void very nicely.
Stop worrying.
DRACO A5OG 09-17-2018 08:14 AM
Ouch, okay if there is a high spot, you must take it out as it will cock eye the bearing seat and potentially bind the shaft or accelerate the bearing wear or worse affect the hole rod assembly up to the pistons/cylinders. Just be very mindful how much you take off, this must not be a rush job.
BTW, if you use orange 574 sealant on the original pic of the dent, sealant will dissolve away, again do not worry about, the two little triangle dimples will fill in and stay solid because the other case half will seal it with 574.
Originally Posted by Trakrat (Post 10184556)
Good to know.
Snitzler 09-17-2018 12:43 PM
I would smooth out the half moon looking defect. Lots of stress risers there.
Trakrat 09-17-2018 12:50 PM
Thanks Snitzler… I'll double check to make sure the top is smooth and flat.
