damage on my case... is this an issue?
I noticed that something had fallen into my recently machined case half and damaged part of the mating area and edge. (apparently someone knocked something off a shelf and it fell)
Does this need to be repaired? Is this acceptable still? Please look at pictures and comment. Thanks!!!! ![]()
1987 Porsche 911 Carrera Coupe |
I would just take a flat stone and wrap it with some 600 grit sandpaper and just slowly run over the area until there is no burr left then stop, you will be fine
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate 1967 912-1985 Toyota FJ60 Landcrusier 1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4 1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag 1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS |
A Steve said not a big deal if it is smooth and no lip do not worry too much-it is more to the inside of the case......but, i would send the picture to the machine shop who did the damage and was not careful with your engine case..
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
There are 2 dents where the mating occurs as well as a dent on the outer edge.
the edge is flat, just a couple of dimples/dents and the outer edge is slightly hit.
By the picture it looks to me like that was preexisting when the machine work was done. I don't se any distortion to the machining Mark's, and you say there is no high metal, which would confirm this. If that had happened after machining, that metal would have been displaced causing the adjacent metal to be high. If the mating surfaces are smooth you are good.
trakrat..i c, in any case do not worry too much...............
Ivan
Member 911 Anonymous
+1, Don't worry about it. Thanks goodness you missed the Journals, then we would have a another story here. Just be mindful and keep cats away, darn hair can kill your engine. :-)
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
I did notice a small 'knick' on the edge of one of the journals. The only reason I noticed was from the light bouncing off it and made it shine more than the journal itself. My fingernail catches on it when I run it along the edge. I don't think it should be an issue as it is really small and I should be able to file it down on the outside edge of the journal to smooth it out slightly.
Much ado about nothing,the case sealant will fill that void very nicely.
Stop worrying.
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa |
Ouch, okay if there is a high spot, you must take it out as it will cock eye the bearing seat and potentially bind the shaft or accelerate the bearing wear or worse affect the hole rod assembly up to the pistons/cylinders. Just be very mindful how much you take off, this must not be a rush job.
BTW, if you use orange 574 sealant on the original pic of the dent, sealant will dissolve away, again do not worry about, the two little triangle dimples will fill in and stay solid because the other case half will seal it with 574. Quote:
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 09-17-2018 at 08:17 AM.. |
I would smooth out the half moon looking defect. Lots of stress risers there.
1988 Carrera coupe 1966 250 Ducati 2015 VW Golf TDI gone because Dieselgate! 2021 VW Golf TSI 2014 Ninja 300 |
Thanks Snitzler… I'll double check to make sure the top is smooth and flat.
