-   -   3.2 partial drop-engine support? (http://forums.pelicanparts.com/porsche-911-technical-forum/1007979-3-2-partial-drop-engine-support.html)
gwinnch 09-16-2018 10:39 AM
What's the best spot to support the 3.2 during a partial drop? Can't seem to talk myself into putting the jack, with folded towel on a block of wood, under the case seam.
should I put a block of wood under each heat exchanger and bridge across with another piece-jack in the middle?
Or where?
Or am I thinking too hard?
da Vinci Dan 09-16-2018 10:54 AM
I have used something similar to what is below. Although not a 3.2 the concept is similar. I think it is an ATV / motorcycle jack.
http://forums.pelicanparts.com/uploa...1537120437.jpg
DRACO A5OG 09-16-2018 11:32 AM
+1^, just be careful
EdRogers 09-16-2018 12:57 PM
I've used a cherry picker and a chain bolted to each side of the rear engine support bar. It was pretty solid.
Snitzler 09-16-2018 04:59 PM
This is what I used for a partial lift. You can see the crease in the phone book.
http://forums.pelicanparts.com/uploa...1537142310.JPG
wareaglescott 09-16-2018 05:41 PM
Best use of a phone book I have seen in 15 years! Nice innovative thinking.
gwinnch 09-17-2018 03:56 PM
Where's a phone book when you need one!
Thanks for all responses and please keep them coming-not sure what I'm going to do yet. I think my engine oil cooler has bad seals...
