-   -   How did you route your twin plug wires (http://forums.pelicanparts.com/porsche-911-technical-forum/100833-how-did-you-route-your-twin-plug-wires.html)
cstreit 03-05-2003 06:14 PM
Guys,
I'm having a hell of a time trying to cleanly route all 12 wires from the electromotive to the plugs.
First, no one offers 6 wire guides that help space the wires away from the block. The kits that are made are for 3 or 4 wires. I've got them routed but honestly feel they look cludgey.
Can you send me some advice and better yet, some photos?
Thanks,
82SC 03-05-2003 07:04 PM
http://www.ultimategarage.com/abaprice.html
RUBBER SLEEVE CLAMPS
the rubber clamps can be ordered from Porsche/Pelican
they come in various sizes
it is what the factory used
http://forums.pelicanparts.com/uploads/dual plug.jpg
the clamps are used at al the shroud to fan bolts and the valve cover studs...notice the spark plug holders too
http://www.bughaus.com/beetle33.htm
the could be used in combination too...I don't know if the diameter is correct...but may clean up the bay a little
MJ
CamB 03-05-2003 07:55 PM
Mine goes under a 964 thingy from the distributor over top of the fan. You're not burdened with a dizzy any more, so no use trying that for you...
I dunno. They tend to naturally fall into bunches of three (three each side of the engine, two sets of three above the tin, two below the tin).
I better go look at your pics on the other thread.
Ooooh, I think there must be a better way to get them under the tin than that! I have a set of 964 wires, so they actually have a suitable rubber bung where it goes through the metal.
Hmmm, sorry - I'm not helping at all.
cstreit 03-05-2003 08:23 PM
So I guess it's acceptable to have the wires touching each other like that. For some reason I thought it wasn't.
I was thinking about a hole saw and a nice rubber sealing grommet throgh the tin...
