broken key
was going to let a porschephile friend drive and he broke the key off in the ignition! Had just lost my good key and hadn't gotten a new one made yet, this was my old spare. Rotten luck!
![]() Can crank the car with a screw-driver. Any advice? |
1988 Carrera
try hemostat Worked for me .
88' Carrera 79' SC gone (lost to Katrina) 75' Targa gone 72'914 gone 72' 914 gone too |
Two sturdy hat pins top and bottom and lever it out.
Strong magnet? Worst case get a locksmith to come to you. I wouldn't mess around with a screwdriver. It will cost you a *****load of $ if you mess up the cylinder.
Jason
'79 911SC Targa |
Thanks gentlemen. Appreciate your suggestions.
Still here
Hat pins ... don't have any, let alone a sturdy one. Don't have a hemostat either for that matter.
OP, Is the key broken completely flush ? No stub to grab on to ? |
Finishing nail would make a good hat pin for me. Grind/file if needed.
Haven't tried it yet, but I got some of that super glue that cures instantly with ultraviolet light. Would be interesting to see if that had enough strength to do a temporary bond. Couldn't be sloppy in applying it, of course.
'88 Carrera Guards Red '70 VW Beetle Yukon Yellow
Wow. Sure never would’ve thought of that!
Dentists have used this UV curing cement for crowns, etc. for quite a while.
Would need an instant bond to try to pull the stub out.
