Squared door mirror cannot stand still
Hello,
I have a 911 1974 2700 with the squared cromed door mirror. By the time is getting harder and harder to put in place - cannot stand still. Keep moving by itself....any suggestion how to fix it? (I would like to keep it and not buying another one). Thank you, Luca |
pry out the plastic trim carefully and extract the glass mirror. Behind this glass is a nut sitting on a spring and ball socket. You have to tighten the nut.
Hello,
finally I got time to do it but it seems a little bit complicate - I'm afraid to damage the gasket. Do you have any suggestion for that (like which tool to use, where to start, etc...). Thank you, Luca |
I bought these for my Rat Rod, and loved them. But in less than a year they were corroding. ESP the shaft between the foot and the mirror body. I need to go back to Porsche and get new ones. Luckily my dealer is very good about things like that.
I think it’s like the hood badges, the quality control has gone down hill, maybe production has moved to Asia or something. A friend has purchased and had to return several badges.....as they fall appart within 6 months. |
Getting the mirror and plastic retainer is not easy. I broke my mirror in the process.
Well, mine is the original one..it's perfect, mint conditions but is sagging on a side
Are these different than the 73? I tighten it through the hole at the bottom.
Hi again and Happy New Year!
Today: no kids no wife perfect day to fix some things on my car - among the other the side mirror. The stupid mirror has been put in place (see pictures) with bolts not parallel to the accessing holes - what's the magic trick or tool to remove them? I can't succed with my wrench since the accessing holes are kind of narrow.http://forums.pelicanparts.com/uploa...1546450525.jpg http://forums.pelicanparts.com/uploa...1546450525.jpg |
| All times are GMT -8. The time now is 04:23 PM. |
