Lucky Luca
Squared door mirror cannot stand still
Hello,
I have a 911 1974 2700 with the squared cromed door mirror. By the time is getting harder and harder to put in place - cannot stand still. Keep moving by itself....any suggestion how to fix it? (I would like to keep it and not buying another one).
Thank you,
Luca
______________________________________
Porsche 911 2700 1974 Gelbgrun
Honda CB 400 F SuperSport 1976 Candy red
Yamaha FZ750 1985 Grey/Red
Old 09-24-2018, 03:04 AM
I would rather be driving
jpnovak's Avatar
pry out the plastic trim carefully and extract the glass mirror. Behind this glass is a nut sitting on a spring and ball socket. You have to tighten the nut.
Old 09-24-2018, 05:06 AM
Lucky Luca
Porsche Crest
Hello,
finally I got time to do it but it seems a little bit complicate - I'm afraid to damage the gasket.
Do you have any suggestion for that (like which tool to use, where to start, etc...).
Thank you,
Luca
Old 12-24-2018, 12:21 AM
Lucky Luca
Old 12-24-2018, 12:24 AM
I bought these for my Rat Rod, and loved them. But in less than a year they were corroding. ESP the shaft between the foot and the mirror body. I need to go back to Porsche and get new ones. Luckily my dealer is very good about things like that.
I think it’s like the hood badges, the quality control has gone down hill, maybe production has moved to Asia or something. A friend has purchased and had to return several badges.....as they fall appart within 6 months.
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 12-24-2018, 09:11 AM
Harpo's Avatar
Getting the mirror and plastic retainer is not easy. I broke my mirror in the process.
Old 12-24-2018, 09:15 AM
Lucky Luca
Well, mine is the original one..it's perfect, mint conditions but is sagging on a side
Old 12-24-2018, 09:44 AM
Are these different than the 73? I tighten it through the hole at the bottom.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 12-24-2018, 02:48 PM
Registered Minimalist
75 911s's Avatar
Shouldn't be. Take the mirror off and tighten from within the base, then re-mount it.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 12-24-2018, 03:40 PM
Lucky Luca
Hi again and Happy New Year!
Today: no kids no wife perfect day to fix some things on my car - among the other the side mirror.
The stupid mirror has been put in place (see pictures) with bolts not parallel to the accessing holes - what's the magic trick or tool to remove them? I can't succed with my wrench since the accessing holes are kind of narrow.
Old 01-02-2019, 09:37 AM
