Shaun @ Tru6's Avatar
George's headers for 3.2
For a stock 3.2 with sport muffler and Steve Wong chip, are 1 3/4 OD & 1 5/8 ID Georges headers too big?
Tru6 Restoration & Design
Old 05-02-2018, 01:53 PM
Bill Verburg's Avatar
1 3/4 OD & 1 5/8 ID = OD too big, even w/ a chip yiot rare still rev limited to 6500 w/o internal mods.
1 1/2" OD(1/3/8" ID) = about right
biggest knock on these is the mild steel construction, which will rot, and lack of heat
Bill Verburg
Old 05-02-2018, 04:04 PM
Thanks Bill, appreciate it. What about 1 5/8 OD?
I will high heat Cerakote them so they should be fine.
Old 05-02-2018, 04:10 PM
I meant to type 1 5/8" OD(1 1/2" ID) just got distracted
Bill Verburg
Old 05-02-2018, 04:13 PM
ok, thanks.
Is that a straight through rally type muffler or does the exhaust snake through baffles on inside? Location of the placements of the exit pipes were the 3.0 rs rallye/rsr?
Old 05-02-2018, 07:35 PM
I am not sure, I'll ask my customer.
Old 05-03-2018, 04:08 AM
Is there a performance advantage to have headers vs a cat by bass and free flow muffler on an otherwise stock 3.2?
Old 05-03-2018, 04:39 AM
Headers work wonders when they have valve overlap to work w/. Put mufflers on the headers and the benefits are muted.
stock 3.2 has cams with very little overlap(8.0°), compared to say S cams w/ 72.0° of overlap
On a stock 3.2 a cat bypass + freeflow muffler will be a very cost effective option, which will deliver performance comparable to muffled headers, because all you are looking for is efficient flow volume, not tuning effects
Bill Verburg
Old 05-03-2018, 05:22 AM
Thanks Bill.
Just got my first air cooled 911. Trying to figure things out
Old 05-03-2018, 05:57 AM
I can add to what Bill says.
Most of my cars are as light as possible. My 73 had a 3.2 with George's headers (not sure on size but almost certainly 1 5/8 based on what Bill says and how the car performed) and gutted muffler and Steve Wong chip. The car was a complete package with mild sport suspension mods and weighed in at 2174 lb. Most fun car I've ever owned and the motor was a big part of it. Cheapest "3.6" ever. It's sitting on a dolly right now for rust repair, that motor is gone, want to duplicate it.
What I like about headers is you are saving at least 40 lb if not more. I know they are below center of gravity lb but weight is weight.
Old 05-03-2018, 06:04 AM
porsher
aston@ultrasw.c's Avatar
I used the European Racing aka george's aka GT racing headers in 1 3/4 on my 3.2
for several years.
I was very pleased with them.
Did not do back to back dyno testing with 1 5/8 of course.
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 09-26-2018, 04:14 PM
I just went to fit my georges headers to my 3.0.. did not realise I needed to backdate the oil lines..
Old 09-27-2018, 04:36 AM
I agree 1-5/8" is ideal for a stockish 3.2 ..
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 09-27-2018, 03:36 PM
