Crew Chief
i would like to upgrade my 71 911T brakes to 84 Carrera or SC brakes , is this a bolton or are there adapters required ? Any other tips ? Or are there any other brakes that will interchange ? Caliper spacing etc. ?
Just get the complete strut assembly off an SC or Carrera. Should be a quick upgrade and easy replacement. (Strut,rotor,Hub,caliper)
Crew Chief
What about the rear ?
rear is a direct bolt on if you have vented rotors. I put 86` carrera brakes on my 69` and I used the struts and rotors for the front and rotors and calipers for the rear. My car originally had solid rotors.
------------------ 69` RS carrera clone 2.7 CIS |
Insert Tag Line HERE.....
I have a complete set of SC brakes and struts for sale...... interested let me know,.....
Marc [This message has been edited by rattlsnak (edited 11-07-2001).] |
Schleprock
If you're going to do it, might as well get the larger heat sink/capacity of the Carrera setup (thicker rotors).
Just my opinion. ------------------ Kevin 87 Carrera coupe |
The 914 guys are always looking for the early strut assemblies so getting rid of your old setup should be easy.
------------------ Mike Mueller Antioch, CA '75 914 2.0 http://www.pelicanparts.com/MotorCity/mmueller/personal.html |
