'72 wiring diagram...
Any source for a good '72 wiring diagram I can print off in BIG letters? Search not real helpful. I'll need help anyway as I'm colourblind so I'm behind the eight ball to start with!!
Putting together my '72 targa and of course I seem to have some "extra" wires going to the front turn lenses, etc.
1971 914- original owner 1973 914 2.0 2018 911 carrera T 2016 981 Spyder PTS |
If you have a shop manual, pull out the beautiful,colored wiring diagrams and take them to your local Office Max printing department, have them copied in 11x18 size or larger if possible, and laminate them. People will try to buy them from you when they see them.
If you don't have the manuals, go to your local Porsche shop (not the dealer), borrow or rent his, and bring lunch for the whole shop when you return them. Bill S. |
How many fuses do you have up front?
'70 911S 1002938 '70 Ducati Mark 3D 350 |
18 fuses, 2 blocks.
Found early911nz downloads. Need to get the factory shop manuals- have had my 914 manuals for over 40 years- need to bite the bullet and get them for the 911...
Under the radar
I enlarged the diagrams from my Haynes. All black and white. I used a zerox set to enlarge. They worked great.
If you do a careful Google search you can find 911 wiring diagrams. I'm not sure if you can find a dedicated '72 diagram. You may have to settle for a '71. Most of these old cars would have some unique options so no schematic will be 100% accurate at any rate.
I am thinking a wiring diagram for the 1973 is the same as a 1972.
Under the radar
Could be. But then there are carbs, mfi, or cis to consider as well.
A '72 911T would not have CIS since it was not introduced until midway in the 1973 production run.
ROW '78 911 Targa
Timmy2, his car has 12 fuses, Sherwood’s link has only 8.
ROW '78 911 Targa
Did you scroll down?
SL 35 has 18 fuses.
Under the radar
That is, I believe, a '69 diagram FWIW. Most of the wiring will be the same as a '72, I would guess. There is an "intermediate unit" in the tach circuit which was only used in '69-'70. The '71 diagrams were split into two parts.
That would be a 10 and 8. Check this out... it might not be exact, but it might help
early wiring diagram - download here
ROW '78 911 Targa
On the link I posted:
SL33 is the ‘69. SL 35 is the 70 as indicated by the dual blue yellow wires going to the coil. In ‘71 that was deleted by elimination of the intermediate unit for the tach, and they did split the drawings into 2 parts. I have all the factory drawings and copies that are blown up. ‘71, ‘72, ‘73 and 73.5 CIS all have their own schematics. They are needed for each year as Porsche changed minor things every year....
1972 911 T E S wiring diagram for ya:
![]() http://content.us.porsche-clubs.porsche.com/PorscheClubs/klassieke-porsche-911-en-912-club/files/electric_wiring_diagram_1972.pdf
Thomas __________________ 1973 911S Targa 2.4 |
No but now I did. Thanks!
