86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Rear Deck Lid Seal.
The rear deck lid seal on our M/Y 86 measures 33 1/2 wide
with one plastic retaining screw on each end.
Every source I've tried stocks a replacement seal which
is only 31 inches wide, and, no mounting screw holes?
So where can I find the correct seal?
Thanks in advance,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 12-09-2015, 01:54 PM
That's fond- just deglaze
Hi 86 911 Targa- Thank you for measuring and posting! I am also very interested if anyone has any insight into this question. I am convinced that 1986 was a completely different strip than the standard part #911.512.129.00. '86 is clearly wider and longer than from '74-'85. Sorry I can share no updates.
Old 12-09-2015, 03:03 PM
Deck lid seal
I ordered one from our host & it was too narrow.
Tried two other sources, no joy....
I would even settle for a used one in good condition!!!
Thanks,
Gerry
1986 911 Targa.
Only in L.A.:
Old 12-09-2015, 03:21 PM
Seal screws & inserts
Seal screws & inserts.
1986 911 Targa.
Only in L.A.:
Old 12-09-2015, 03:52 PM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
Interesting Gerry. When I replaced mine, there were no plastic screws. So either it had been replaced or it never had them. I do not see any screw holes, where are they located? The replacement, from Pelican, measures 32.25 inches and yes it was about half an inch shy from the one it replaced.
Dave
1986 Targa Guards Red
2021 MT09 SP
Old 12-09-2015, 03:55 PM
Dave
Dave,
The screw holes are located at each end of the seal.
I'll get some pics in the am.
Best,
Gerry
1986 911 Targa.
Only in L.A.:
Old 12-09-2015, 04:08 PM
I replaced mine in my '86 and it didn't have screws. I'll post some pics tomorrow. You can have my old one if I can find it.
'86 Carrera
Old 12-09-2015, 08:23 PM
Rear Deck Lid Seal.
Here's what I'm trying to replace.
If the replacement seal can be stretched, I'll drill the screw holes.
Thanks to all for your constructive comments.
Best,
Gerry
1986 911 Targa.
Only in L.A.:
Old 12-10-2015, 07:08 AM
'86 Carrera
Old 12-10-2015, 08:38 PM
^^^ as you can see mine doesn't have those plastic screws and the length is perfect.
My guess is, judging by the age of your seal, that someone added those screws to hold it on.
'86 Carrera
Old 12-10-2015, 08:40 PM
Actually mine have the exact same plastic rivets as his did. The seal I bought on Ebay fits perfectly.
Old 12-10-2015, 09:15 PM
Nothing added.
This is the original seal that came with the car.
Where did you source your seal on eBay?
Do you still have the link?
Thanks,
Gerry
1986 911 Targa.
Only in L.A.:
Old 12-10-2015, 11:35 PM
ahead of the curve
Jeff Burger's Avatar
Isn't this the screw or at least the screw receiver he is talking about?
19 Carrera T - MPS member
92 C2 SR coupe M491/ 3.8 look- manual
92 C2 SR coupe cobolt blue- manual
73 914 1.7 (?) AG -a solid project looking 4 a sugar daddy
73.5 T gemini blue SR coupe sold 8/22 my last long hood gone
Old 12-11-2015, 05:30 AM
It is indeed.
1986 911 Targa.
Only in L.A.:
Old 12-11-2015, 05:37 AM
That is just a plastic piece that fills that hole. The seal is designed to fit along that little metal lip. I looked at a bunch of engine bay pics and it appears they made more than one style of seal. I think though that if you install the one you have by just pressing it on the metal lip you should be fine. They look a little weird and stick up at the ends at first but after a while they sit flatter. You may have to adjust your latch and lid bumpers as well.
'86 Carrera
Old 12-11-2015, 06:26 AM
The one I have is the original, and, is in dire need of replacement.
My choice would be to find the right size, and,
punch two holes on the ends for the attachment screws.
Gerry
1986 911 Targa.
Only in L.A.:
Old 12-11-2015, 06:42 AM
Porsche 911 930 74 86 Rear Engine Lid Rubber Seal | eBay
This is the one I ordered for my 1986 911 and it fit perfectly. I did not use either of the rivets as it laid across and fits snugly without need of any aid. Hope that helps.
Old 12-11-2015, 07:13 AM
Thanks, just ordered one.
1986 911 Targa.
Only in L.A.:
Old 12-11-2015, 07:31 AM
Hope it works as well for you as it did for me.
Besides I grew up in MB so anything for a homie.
Old 12-11-2015, 07:39 AM
I ordered from your source, and, as you posted, the seal was an exact replacement.
Spot on! Well done!
Our host should have this size.
Best,
Gerry
1986 911 Targa.
Only in L.A.:
Old 12-16-2015, 09:06 AM
