I’m not says no you can’t convert a 923 to actuate like a 915. I am a KISS, guy. Keep it simple stupid. If I can put a 911 engine in the car and change NOTHING but the engine, that’s what I’m going to do. A 1977 was a 2.7. If it were my car I would find one and install it.
If 3.0 or 3.2 is your end goal, find a 915 gearbox and install it at the same time. A 923 gearbox is worth $500+/- more than a same or similar year 915. Makes no sense to me to chase all these clutch flywheel bearing work arounds. Again, back to kiss. |
The guide tube is a just fit into the TOB slop shouldn’t be part of the guide....
Bruce |
Matt,
I'm with your same thinking. I want to keep it as simple as possible. I'm asking these questions so that I will know if I need to source a different trans. Sounds to me like it should work without needing to do anything special. |
Yep. I personally like how a 2.7 revs. And the 923 has a 7:31 like a 74 had. In my eyes it makes for a nice little middie.
Matt keeping in line with the KISS method, wouldn't a 3.0 bolt the same as a 2.7?
Yes. Pressure plates and flywheel have the same cross section having nothing to do with
Crank bolt count Bruce |
| All times are GMT -8. The time now is 07:59 PM. |
