Checking Matching Numbers
How long does it take to check if a car is matching numbers or not ,is there a site you can go on to do this or do you have to wait for a COA
Thanks |
Post your numbers and someone here can most likely tell you. Not I unfortunately.
Den912,
What I did was called Porsche North America and ask them if they could verify the numbers for me. They will confirm if there is a match over the phone (as long as you provide VIN, engine and transmission #) Hope that helps... Sent from my iPad using Tapatalk |
Thanks |
@den912,
Just call 1-800-PORSCHE and via the menu you can get to Customer Relations |
My guess would be +44 3457 911 911 (number that showed up in google when searching for UK)
| All times are GMT -8. The time now is 04:59 AM. |
