Checking Matching Numbers
How long does it take to check if a car is matching numbers or not ,is there a site you can go on to do this or do you have to wait for a COA
Thanks |
Post your numbers and someone here can most likely tell you. Not I unfortunately.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Den912,
What I did was called Porsche North America and ask them if they could verify the numbers for me. They will confirm if there is a match over the phone (as long as you provide VIN, engine and transmission #) Hope that helps... Sent from my iPad using Tapatalk |
Without contacting porsche no one can say whether the numbers match. The best someone here can do short of that is to tell you whether the numbers are correct to the year and model of the car
Thanks |
@den912,
Just call 1-800-PORSCHE and via the menu you can get to Customer Relations |
My guess would be +44 3457 911 911 (number that showed up in google when searching for UK)
